Community Member
failed pings...
could this be cuased by errors on the link?...not even one packet passed..but after i changed the amount..it did..
04#ping
Protocol [ip]:
Target IP address: 192.168.7.73
Repeat count [5]: 100000000
Datagram size [100]: 10000
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 100000000, 10000-byte ICMP Echos to 192.168.7.73, timeout is 2 seconds:
Success rate is 0 percent (0/49)
t04#ping
Protocol [ip]:
Sending 10000, 1000-byte ICMP Echos to 192.168.7.73, timeout is 2 seconds:
1 ACCEPTED SOLUTION
Community Member
Re: failed pings...
Look closely...the datagram size in the first set of pings is 10,000...in the second it's 1000. I don't know of any interface that handles 10000-byte packets.
Community Member
Re: failed pings...
I think you choose very large number of ping packets on (repeat count), so your router does not able to deal with.
Re: failed pings...
Are you actually having a problem that you're needing to figure out, or is it primarily the high packet count that you're asking the router to push out? I've never used that high of a number before, so I'm not sure what you should expect really.
--John
HTH, John *** Please rate all useful posts ***
Community Member
Re: failed pings...
yes...We are trying to set up etherchannels to HP virtual connect.
The IP is one of the servers on the blades.
The link keeps dropping for some reason.
We are seeing tx/rx errors on the swithcport
of the blades..
but cisco side is totally clean
Re: failed pings...
I would set your speed and duplex settings manually.
Community Member
Re: failed pings...
thmm..he ping was from a switch to a server
Community Member
Re: failed pings...
Check your datagram size in the first set of pings.
Re: failed pings...
Do you have any errors on the link? The datagram size shouldn't be the problem; it's the same in both pings.
Community Member
Re: failed pings...
Re: failed pings...
Oops...I didn't see that other 0. Good catch. :-)
Community Member
Re: failed pings...
great..thx!!
163
