I've read previous issues related to this error while booting the Cisco 837 SOHO....i also tried the solution suggested in previous issues, by changing & testing all speeds supported in rommon mode but the output is same w/ garbage, after that i also changed the IOS through tftpdnld utility.............but still garbage
CISCO C837 (MPC857DSL) processor (revision 0x600) with 58983K/6553K bytes of memory.
Processor board ID FHK091712FV (2767348863), with hardware revision 0000
CPU rev number 7
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
128K bytes of non-volatile configuration memory.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
dsl power-cutback 0
% Invalid input detected at '^' marker.
Failed to change line 1's speed
Press RETURN to get started!
àüüàüüüàü
help
Akhtar
