Failed to start Kadis
Does anybody know what following log message is related to?
"Failed to start Kadis. Status -10"
Appears shortly after bootup, once.
7204VXR/NPE-2G with EIGRP, BFD, some QoS
Alex
Re: Failed to start Kadis
What is the IOS version of IOS?
12.2(4)XD8, Advance Security.
I think it may be related to BFD. not sure though
Alex
Yes...it is BFD related and the problem is with BFD support on NPE-G2. This problem is fixed in 12.4(16.5)T or higher. This version is not available on CCO for you to download yet. You can request a TAC engineer to post an Engineering Special with the fix if you would like to test.
Thank you for the info!
I am currently on (15)T1 version and you are saying that it is not going to work until (16.5)T.
I see some bfd behavior that doesn't correlate to docs, and it may be due to above.
If this technology is such hot, may be it is not a good idea to use it under EIGRP for WAN failures detection over ISP's switched Ethernet links? We are cutting over next month.
Reduced timers?
Alex
318
