FAILOVER AND LOAD SHARING
Hi.
I have 4 cisco 2610 with 2 serial wan connection to 2 line 2 mbit.
I configured hsrp so each pair of route has virtual ip for failover.
If i want to configure load balancing or load sharing how can i do? With EIGRP? BGP? How can i mix all? Can you give me some hint and link to docs to read?
Thx.
1 REPLY
Silver
Re: FAILOVER AND LOAD SHARING
You can configure load sharing for HSRP. Offcourse there are sever ways to accomplish this. In the Cisco example 2 standy groups are used. The downside is that it requires additional configuration on your hosts.
A newer technology called Gateway Load-Balancing Protocol, which is derived from HSRP is more likely to use but is likely not available to the 2600 series platform. See feature navigator.
I suggest you start here:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094e90.shtml
EIGRP, PBR and BGP are also posibilites it depends on your design and business requirements how and where to implement them.
Leon
* Please rate useful posts.
103
