Failover between T1 & DSL WAN Cards on 2621?
Can the Cisco 2621 with a T1 and a DSL connection on the two WAN ports be used as a failover? We use the T1, but want to use the DSL as a backup instead. I do believe that I can load balance between the two WAN ports...
Blue
Re: Failover between T1 & DSL WAN Cards on 2621?
you can setup the dsl to be used as a backup by creating a static route for the dsl link with a higher cost to the destination.
this way, when the lower cost T1 fails, the router still has a route, via dsl, to your destination.
see the following link on unEqual cost load balancing as well. (igrp/eigrp)
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009437d.shtml
you can always make an interface for failover by giving following commands on that interface
"backup interface
backup delay 1 1"
Pls rate all posts
JD
110
