Failover Connectivity in RIP v2
Maymar Branch has dual connectivity(DXX & Radio). we want the Radio Link as a primary and DXX Link as a secondory & when the primary goes down the secondary takeover but the traffic goes through the DXX link because of less no. of hop counts and Radio Link treated as a secondary link, all the router & switches are running on rip version 2 protocol.
regrads
Salman
Re: Failover Connectivity in RIP v2
Hi Salman
use offset lists to modify RIP hop counts.
this will allow you to increase number hops seen from DXX.
Sam
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfrip.html#wp1017883
Hi Sam,
Thanks for your helpful response this will work on only one condition when i shutdown the DXX interface on Maymmar branch did this work only on failover condition .
I need to know one more query from you i.e
1) If i run RIP v2 on Maymmar how would i be make radio link as primary and DXX Link as secondary link.
Is there any command in RIP v2 to make primary route and secondary route. I also attached Maymmar router configs.
regrads
Salman
Hi Salman
Under routing process add
router rip
offset-list 10 out 5 s0/2/0
offset-list 10 in 5 s0/2/0
access-list 10 permit x.x.x.x y.y.y.y
the above will add a metric of 5 when sending via ur backup link and 5 when receiving via backup link.
x.x.x.x is the Prefix u wish to apply this offset to.
do sh ip route before and after this to validate the changes.
Sam
Hi Sam,
After your recomendation this was the result i found
Trace from Branch Switch to Maymmar server
BranchSwitch#traceroute 10.0.14.0
Tracing the route to 10.0.14.0
1 10.254.1.2 80 msec 80 msec 48 msec
2 10.0.2.2 60 msec 56 msec 64 msec
3 10.254.1.105 92 msec * 76 msec
Trace from Maymmar to Branch Switch server
Maymar#traceroute 10.20.0.1
Tracing the route to 10.20.0.1
1 10.254.1.89 60 msec 48 msec 32 msec
2 10.20.3.1 88 msec * 92 msec
I want Maymmar traffic goes from radio link not secondary link.
where did u make the changes I suggested ?
Please paste ur rip config and sh ip route for Branch switch and maymar server.
Sam
Today i did this and it will work fine.
access-list 1 permit 10.0.14.0 0.0.1.255
access-list 2 permit 10.20.0.0 0.0.1.255
router rip
offset-list 1 out 4 s0/2/0
offset-list 2 in 4 s0/2/0
Well thanks for your help and time to answer in the discussion forum.
regards
Salman
Glad to help.
I have given u example and method and u found the right way to apply it to ur set up.
Well done !
Sam
1244
