Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Failover on 2611XM using two ISP.
I have two ISPs connected to my 2611XM. I use Cable connection as the primary connection and want to use DSL as the backup. I tried doing this using the track 123 rtr 1 reachability but couldn't get it working. I would appreciate if anyone could help me on this. Here's the config on the router. Also attached is the diagram for my topology (failover.jpeg)
c2600-adventerprisek9-mz.124-17.bin
FAILOVER#sh run
Building configuration...
Current configuration : 2314 bytes
version 12.4
service password-encryption
hostname FAILOVER
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp pool FAILOVER
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.2 42.63.84.25
lease 4
ip sla monitor 1
type echo protocol ipIcmpEcho 42.63.95.1 source-interface FastEthernet0/1
timeout 1000
threshold 40
frequency 3
ip sla monitor schedule 1 life forever start-time now
ip sla monitor 2
type echo protocol ipIcmpEcho 131.10.28.24 source-interface Dialer1
timeout 1000
threshold 40
frequency 3
ip sla monitor schedule 2 life forever start-time now
vpdn enable
track timer interface 5
delay down 15 up 10
track 345 rtr 2 reachability
delay down 15 up 10
interface FastEthernet0/0
description INTERNAL_LAN
ip nat inside
ip virtual-reassembly
duplex auto
speed 100
description CABLE
ip address 42.x.x.47 255.255.252.0
ip nat outside
speed 100
full-duplex
interface Ethernet1/0
description DSL
no ip address
half-duplex
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname username
ppp chap password xxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 42.63.95.1 track 123
no ip http server
no ip http secure-server
ip nat inside source route-map CABLE interface FastEthernet0/1 overload
ip nat inside source route-map DSL interface Dialer1 overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map CABLE permit 10
match ip address 100
match interface FastEthernet0/1
route-map DSL permit 10
match interface Dialer1
control-plane
line con 0
line aux 0
line vty 0 4
end
FAILOVER#
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Failover on 2611XM using two ISP.
No idea, you should look at SIP traces to see what's going on.
Perhaps the server is not configured to handle the phones coming in with another address.
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
What is not working exactly?
If the issue is that the NAT translations remaining after a route is removed, you should use "oer" keyword in "ip nat ....". I'm not sure it is available in 12.4 mainline, however.
Thanks for you reply.
The failover doesn't happen at all. AFter the cable link goes down the traffic doesn't transition to DSL.
I am sure that there's something that I did wrong in the configuration.
Thanks in advance for your response.
indeed you also need a default route with higher distance (aka floating) pointing to dialer interface.
Does the backup floating route also need to have a track at the end.
I tried using
ip route 0.0.0.0 0.0.0.0 dialer 1 track 345
But that also did not work.
I didn't try using it with a higher metric though.
Any thoughts would be appreciated.
Hi there,
I did a floating route as you said.
ip route 0.0.0.0 0.0.0.0 dialer 1 5
Now the backup route kicks in after the primary route fails. But I have to clear NAT translations before a host could go to outside world.
I don't have the option to use ip nat translation tcp-timeout OR udp-timeout because there are application which will not work after doing this.
I would really appreciate if you could guide me little more as I think that I am somewhere near to get it working.
P.S. I read something about Stateful NAT, not sure though if that fits in my issue or not.
Hi, as you found yourself, you don't need a tracking statement if the DSL access is meant for backup only.
I don't think stateful NAT would help as it is meant to address other needs (equipment redundancy rather than circuit redundancy).
What you need is to upgrade to one of the latest 12.4 T releases, once you configure the oer keyword to "ip nat ...", all translation should be removed once the primary route is no more.
Of course from that point on, traffic to the internet would take the DSL address, as you cannot use an address belonging to a circuit to a different one, and there is no configuration or workaround that would allow that.
Hi there,
Thank you so much for your guidance. I used oer at the end of IP nat statement and it works.
The small problem here is that my computer works fine after a failover happens however, my ip phones (registering with asterisk server) don't work. I tried decreasing the registeration time to 60 seconds. But again the phone doesn't register and cannot do outbound and inbound calls. This also happens with Soft phone.
I also tried using
ip nat translation udp-timeout 10 (thinking that after every 10 seconds the entry will delete and the phone will create new entry).
Any suggestions on this would be highly appreciated.
406
