Failover WAN on 881 using Fast4 and VLAN on Fast3
I am looking for confirmation that I can use an interface other than the fastethernet4 as my ip nat outside on an 881.
Background:
We use 881g with the fast4 and cellular0 interfacs for WAN failover and wanted to do the same on an 881 without the wireless card.  We want to use fast4 as our primary WAN connection to the Internet and use VLAN3 on an interface on the 4 port switch.
The configuration commands do not error, but we get no nat trans via the outside interface if it is the VLAN based interface.
It seems therre maybe a limitation on this functionality but I do not see why this should be.
Here is the relevant info:
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 3
interface FastEthernet4
description Comcast Cable Internet
ip address dhcp
ip nat outside
ip virtual-reassembly
zone-member security zone-outside
duplex auto
speed auto
interface Vlan1
description inside
ip address 192.168.40.1 255.255.255.0
ip nat inside
zone-member security zone-inside
ip tcp adjust-mss 1452
interface Vlan3
description BACKUP Internet
ip address 64.xxx.xxx.xxx 255.255.255.248
ip nat outside
I have correct route-maps for nat and an sla/track.  Again, these concepts are proven on an 881g.  I cannot find a statement that says you cannot use a vlan as the outside.  The router itself can use the vlan3 backup just fine, it is NAT that fails.  Perhaps an 891 with GE/FE on the WAN is the only way to do this.
Thanks in advance!
1 REPLY
Purple
I think so ,yes
Regards.
Alain
303
