Webcast-Catalyst9k
FAILURE id 1 len 14 msg is "RejectedJM"
I am getting the error below on a ADSL WIC in a 1751 router, anyone know what it means?
Oct 10 11:55: 22.275: Vi2 LCP: State is Closed
Oct 10 11:55:22.275: Vi2 PPP: Phase is DOWN
Oct 10 11:55:22.275: Vi2 PPP: Phase is ESTABLISHING, Passive Open
Oct 10 11:55:22.275: Vi2 LCP: State is Listen
Oct 10 11:55:23.199: Vi2 LCP: I CONFREQ [Listen] id 2 len 15
Oct 10 11:55:23.199: Vi2 LCP: AuthProto CHAP (0x0305C22305)
Oct 10 11:55:23.199: Vi2 LCP: MagicNumber 0x9546E095 (0x05069546E095)
Oct 10 11:55:23.199: Vi2 PPP: No remote authentication for call-out
Oct 10 11:55: 23.199: Vi2 LCP: O CONFREQ [Listen] id 73 len 10
Oct 10 11:55:23.199: Vi2 LCP: MagicNumber 0x0910B1E9 (0x05060910B1E9)
Oct 10 11:55:23.203: Vi2 LCP: O CONFACK [Listen] id 2 len 15
Oct 10 11:55:23.203: Vi2 LCP: AuthProto CHAP (0x0305C22305)
Oct 10 11:55:23.203: Vi2 LCP: MagicNumber 0x9546E095 (0x05069546E095)
Oct 10 11:55:23.207: Vi2 LCP: I CONFACK [ACKsent] id 73 len 10
Oct 10 11:55:23.211: Vi2 LCP: MagicNumber 0x0910B1E9 (0x05060910B1E9)
Oct 10 11:55:23.211: Vi2 LCP: State is Open
Oct 10 11:55:23.211: Vi2 PPP: Phase is AUTHENTICATING, by the peer
Oct 10 11:55:23.211: Vi2 CHAP: I CHALLENGE id 1 len 37 from "RAS1NRP4.Douglas"
Oct 10 11:55: 23.215: Vi2 CHAP: Using hostname from interface CHAP
Oct 10 11:55:23.215: Vi2 CHAP: Using passworundebug all
Oct 10 11:55:23.215: Vi2 CHAP: O RESPONSE id 1 len 38 from "secret@homesurfer "
Oct 10 11:55:23.243: Vi2 CHAP: I FAILURE id 1 len 14 msg is "RejectedJM"
Oct 10 11:55:23.243: Vi2 LCP: I TERMREQ [Open] id 1 len 4
Oct 10 11:55:23.243: Vi2 LCP: O TERMACK [Open] id 1 len 4
Oct 10 11:55:23.247: Vi2 PPP: Sending Acct Event[Down] id[5AB4]
Oct 10 11:55:23.247: Vi2 PPP: Phase is debug atm events
Oct 10 11:55:24.395: Vi2 LCP: I CONFREQ [TERMsent] id 1 len 15
Oct 10 11:55:24.395: Vi2 LCP: AuthProto CHAP (0x0305C22305)
Oct 10 11:55:24.395: Vi2 LCP: MagicNumber 0x9546ED04 (0x05069546ED04)
Oct 10 11:55:24.395: Vi2 LCP: Dropping packet, state is TERMsent
Oct 10 11:55:25.251: Vi2 LCP: Timeout: State TERMsent
Oct 10 11:55:25.251 : Vi2 LCP: State is Closed
Oct 10 11:55:25.251: Vi2 PPP: Phase is DOWN
Oct 10 11:55:25.251: Vi2 PPP: Phase is ESTABLISHING, Passive Open
1 REPLY
Hall of Fame Super Gold
Re: FAILURE id 1 len 14 msg is "RejectedJM"
John
It looks to me like the messages indicate that a ppp session is being initialized, it gets to the authentication step (configured to use CHAP), that you send a password and that the other device rejects the password that you sent. The session is then torn down. I would suggest that you review your configuration and especially that you check the value of the password that you have configured with what the other device is expecting.
Rick
435
