07-27-2006 03:31 AM - edited 03-03-2019 01:28 PM
I need at least 4 ports on 7206 VXR.
I guess it should be something like PE-FE....Could someone please let me know the exact part name???
07-27-2006 03:45 AM
You probably need the PA-2FE-TX and PA-2FE-FX cards. There is more detail on those here:
Hope that helps - pls do rate the post if it does.
Paresh
07-27-2006 03:46 AM
You can go for a 2 PE-2FE FX/TX
07-27-2006 04:10 AM
Raj,
Your I/O board may have build-in FE ports (Either one or two). If so you will just need to add 2x PA-FE-TX or 1x PA-2FE-TX / FX
hth,
Ajaz Nawaz
07-27-2006 04:35 AM
Hi Friends...
Thanks for the needful.
I do understand the PA-2FE-TX would serve my purpose but isn't there any Port Adapter (PA) which comes with four ports on a single PA instead of having 2 PAs i.e 2 PA-2FE-TX since I need 4 ethernet ports???
07-27-2006 04:44 AM
If iam right you will get an 8E, a 2 FE and 1 GE, there is no 4 FE in the 7200 PAs
07-27-2006 05:07 AM
Raj,
All the options have been discussed. There is no PA available with more that 2FE ports. If you went down to 10mb then yes, you have PA-8E but I understand this is not what you require.
See this url for all the options available to you:
<http://www.cisco.com/en/US/products/hw/modules/ps2033/ps2546/index.html>
hth,
Ajaz Nawaz
please rate all useful posts.
07-27-2006 07:44 AM
not sure if your using an NPE-G1 in you router but the following might be f interest if your going beyond 4 FastEthernet ports on a
router .
Summary:
Oversubscription of bandwidth points is NOT a TAC supported configuration.
Detail:
Cisco 7200 series router with NPE-G1 (3 Gigabit/FastEthernet ports do not take up bandwidth points).
Slots 1,3,5 have a total of 600 bandwidth points max.
Slots 2,4,6 have a total of 600 bandwidth points max.
In all 1200 points
PA-FE-TX/FX = 200 points
PA-2FE-TX/FX = 400 points (.i.e if both ports used)
So:
PA-FE-TX/FX 200 Bandwidth points x 6 = the full 1200 points
PA-2FE-TX/FX 400 Bandwidth points x 6 = 2400 if all ports used
So you can only have a total of six Fastethernet ports on a router.
References:
