fast ethernet
leungcm
Dear Sir,
we get following error on the fast ethernet. we show interface
FastEthernet0/0 is up, line protocol is down
do you know why the protocol down? how do we fix it? please advise.
Best regards
CM Leung
mohammedmahmoud
Level 11
Level 11
Kindly check the cables.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
9 Replies 9
mohammedmahmoud
Level 11
Level 11
Mohammed Mahmoud.
Hi mohammed
His problem with line protocol so when line protocol is down there problem with mismatch config only like (encapsulation, duplex, port settings etc.,)
So Mr. CM Leug plz once cross check your configurations at both ends should be same.
Dear Sir,
Thank you fro your input. The root problem is the cable issue. We re-connect the cable the interface is up again. thanks for your value input.
Best regards
CM Leung
lleopoldo
Where is the fastethernet connected to? If protocol is down, there is mismatch to duplex mode and speed between the fastethernet port and to where it is connected to. Serial up means you got a signal from the interface where you are connected with; line protocol down - means you have mismatch config.
Please rate this if it helps.
Thanks.
After checking the cables please do check the speed, as speed mismatch causes the link to no longer function. (Speed mismatch happens only if statically misconfigured on both ends), while duplex mismatch results in performance-related issues rather than resulting in no connectivity.
Mohammed Mahmoud.
scottmac
Level 10
Level 10
You either have a straight-through cable where a cross-over is needed
or
A cross-over cable where a straight-through is needed
or
Someone has configured your FastEthernet interface for a strange/unsupported encapsulation.
Speed and / or Duplex will not cause this error.
Good Luck
Scott
Hi Scott,
A wrong cable will make your serial "down", not up. His problem is the protocol is down which is related to duplex/speed or port configuration (access or trunk and encapsulation).
We've seen instances where the wrong flavor of cable has caused an Up/Down...it might have been an old switch or combination of old/new, I don't recall.
Agreed that "Protocol Down" is probably a bad encaps ... but it's almost certainly not a speed / duplex thing.
Hi Scott,
Yes, you're right. I just made simulation test and you are correct. Thanks for the info.
