05-02-2006 11:13 AM - edited 03-03-2019 12:35 PM
IN MY NETWORK WHICH WAS WORKING FOR A LONG TIME HAS SUDDENLY A PROBLEM WHICH IS THE FAST ETHERNET PORT GOES DOWN AND AFTER A WHILE IT GOES UP AND SO ON, I DECIDED TO CHANGE THE ROUTER, THE SAME THING HAPPEN IN MY NETWORK, COULD YOU HELP?
05-02-2006 12:23 PM
Your router (assuming the FE is on a router) is probably not receiving the keepalives that are sent every 10s. This is likely due to a network or cabling problem and not a problem with the router itself.
Check what happens when you connect the fe to another switchport. It should stay up.
Leo
05-03-2006 06:41 AM
I did change the routter, the cable and the switch port, it's the same thing.
05-03-2006 06:53 AM
Try no keepalive, on the interface and see if you have a change.
Regards.
