Hi All,
Will the cisco2821-sec/K9 support the following features.
a)PIM-SM and PIM-DM
b) CIDR, VLSM and BGP4.
c) Proper congestion management
techniques.
d) Packet filtering based on IP address, Network address, port number etc.
e) QoS support for Traffic prioritization, differentiated services and committed access rate. The unit(s) should be capable of running RSVP.
f) Bandwidth optimization with Dial backup / Dial-on-demand / Bandwidth on demand / inactivity timeouts / Data compression.
g) Extensive accounting features including Network Time Protocol Traffic polling including the following: Packet & Byte counts / Start Time stamp & End Time stamps / Input & Output Interface ports / Type of service / TCP Flags and Protocol / Source & Destination IP Address / Source & Destination TCP / UDP Address/ Next HOP Address / Source Autonomous No. / Destination Autonomous No. / Subnet Masks
h) Must be capable of multiple access level to manage the router unit(s). Should be capable of supporting RADIUS for authentication
Security
Packet filtering / Access Control mechanism
based on IP and TCP
NAT
PAT
Stateful packet inspection
Activity Logging
Layer 2 authentication for PPP thru PAP / CHAP
Embedded Hardware based VPN support:
IPSEC, MD5, IKE, SHA-1, DES/3DES
What is packet processing capacity per second
Subramanya N.v
