FIFO or WFQ ?
Hi, can you please confirm whether the answer below is correct:
"Which traffic queueing method gives a low-volume traffic stream preferential service ?"
a)FIFO
b)Weighted fair
For me, answer b) is right. However, from reading cisco.com that is not totally clear to me. Can you please confirm ?
1 ACCEPTED SOLUTION
Re: FIFO or WFQ ?
Hi Friend,
The answer is B.
Weighted Fair Queuing". A flow-based queuing algorithm used in Quality of Service (QoS) network applications that schedules low-volume traffic first, while letting high-volume traffic share the remaining bandwidth. This is handled by assigning a weight to each flow, where lower weights are the first to be serviced.
HTH, Please rate if it does.
-amit singh
Re: FIFO or WFQ ?
here weighted fair queue is going to take care of the small bytes of packet... i mean to say is it will take care of the same number bytes from each and every queue...
let say you have two queue one is having packet of 200 bytes and other is having 100 bytes then WFQ will take one packet from first queue of 200 bytes and it will take two packets of the 100 bytes from second queue so total bytes serving for the both the queue is same...
regards
Devang
Re: FIFO or WFQ ?
Ok, but then is WFQ the correct answer for this then ?
Re: FIFO or WFQ ?
Hi Friend,
The answer is B.
-amit singh
797
