Community Member
Filter RFC1918 in OSPF
Have the following ospf config, and am wanting to stop ospf from advertising interface fastEthernet0/0.999 (Which is used for management, and uses range)
router ospf 100
area authentication message-digest
redistribute connected subnets
redistribute static subnets
redistribute rip subnets
passive-interface default
#show ip route
Routing entry for
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via ospf 100
Advertised by ospf 100 subnets
Routing Descriptor Blocks:
* directly connected, via FastEthernet0/0.999
Route metric is 0, traffic share count is 1
ospf is reporting that it is not enabled on the FE subint:
#show ip ospf interface fastEthernet0/0.999
%OSPF: OSPF not enabled on FastEthernet0/0.999
But as it is a connected subnet, it is advertising....
Re: Filter RFC1918 in OSPF
From part of your config I can't see that OSPF is running on any interface at all, since there is no any 'network' or 'neighbor' command, and then all interfaces are passive.
If you want to advertise only some of the connected networks you have generally two options:
1) careful use of 'network' statement will enable OSPF only on the interfaces that should be in OSPF; or
2) using a route-map when redistributing, like
access-list 1 perm
route-map connected-to-ospf deny 10
match ip address 1
route-map connected-to-ospf perm 20
router ospf 100
redistribute connected subnets route-map connected-to-ospf
Both will get right routes into OSPF database, but in case of redistribution you routes will be external Type-2 (unless you also specify 'metric-type 1' in redistribute command), which may or may not be important (depending on your topology). Unless there's specific reason of using redistribution, I'd prefer using 'network' command to choose which directly connected networks should be advertised.
Community Member
Thanks for the reply...
The following ints are non-passive:
no passive-interface FastEthernet0/0.10
no passive-interface FastEthernet0/0.50
no passive-interface FastEthernet0/0.101
no passive-interface FastEthernet0/0.102
no passive-interface FastEthernet0/0.801
no passive-interface FastEthernet0/0.802
no passive-interface FastEthernet0/0.803
no passive-interface ATM1/0.100
no passive-interface ATM1/0.102
no passive-interface FastEthernet4/0
no passive-interface Loopback10
no passive-interface Loopback101
no passive-interface Loopback102
And I do not have a network statement for the I assumed "redistribute connected subnets" was overiding this?
Thanks for the tip on the route-map.
Ok, but you do have 'network' statement covering other interfaces, don't you? Yes, redistribute command doesn't care whether interface is passive or not so route-map is essential tool to control what routes should be redistributed (whether they're connected, static or learned from some other routing protocol).
I'd suggest you to remove 'redistribute connected' command at all, and use 'network' command possible in combination with passive-interface for some interfaces in order to get your connected networks into OSPF.
Community Member
Yes - Have multiple "network" statements covering the other interfaces.
Thanks for the assistance, I'll remove the "redistribute connected" and see how it goes.
