FiOS speed thur Router
I have recently installed FiOS at 2 clients that had WVRS4400N routers. I only get speeds to 10/4 at speedtest.net but if I connect a notebook directly to the FiOS I get the 20/20 speeds they purchased. Is there a way to get higher WAN speeds thru that router.
Hall of Fame Super Gold
Re: FiOS speed thur Router
fios ? 4400 routers ? what is the cisco-specific question here ?
Guess you haven't heard about the Cisco Small Businesss brand check out http://www.cisco.com/web/products/linksys/index.html
Why FiOS as WAN input ... it's speeds can rival a DS3. So as I was saying I have a Cisco branded router with input speeds of 20 Mbit/s Up/Down but only get 4 Up/10Down output... is there someone on this forum who can tell me how to improve the output of this router.
Sorry, despite the what the box says, you have a linksys and not a cisco router. These are not discussed here.
Make sure that the port speed and duplex on your router matches the FIOS Provider connection.
I have a linksys (not 4400) and cannot set duplex. I guest their autodetection is reliable.
But, for a fast circuit, I would use not less than an 871 or even better a 1800.
334
