Community Member
First post and hopefully seaking some help... Cisco 1700 + DSL
Hello Guys!
First post and really hoping to get some help here! Been trying to get this working for a while and with no luck, here is my setup and config: I just can't seem to ping anything (eg. 4.2.2.2) from inside my router.
ISP Provider (PPPoE) - DSL Modem - Cisco 1700
My config:
Current configuration : 2112 bytes
version 12.3
service password-encryption
hostname smith
boot-start-marker
boot-end-marker
enable
enable
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip domain name domain.com
ip name-server 4.2.2.2
ip cef
ip audit po max-events 100
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
username
ip ssh authentication-retries 2
ip ssh source-interface Ethernet0
interface Ethernet0
description ADSL WAN Interface to Velcom
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0
description ADSL LAN Interface
ip address 192.168.1.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip mroute-cache
speed auto
no cdp enable
interface Dialer1
description ADSL WAN Dialer
ip address 64.24.16.19 255.0.0.0
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname $$$$$$$$$@$$$$$$$$.com
ppp chap password 7 $$$$$$$$$$$$$
ppp pap sent-username $$$$$$@$$$$$$$$$$.com password 7 $$$$$$$$$$$$$$
ip nat inside source list 10 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
access-list 10 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
line con 0
password
login
line aux 0
password
login
line vty 0 4
privilege level 15
password
login local
transport input telnet ssh
end
When I turn on logging, nothing really shows up except for this:
00:10:27: Thread slow_thread: Emptyoff
00:10:28: CEF: background resolution thread state:
00:10:28: Thread fast_thread: Empty
00:10:28: Thread todothread: Empty
00:10:28: Thread slow_thread:
00:10:29: CEF: background resolution thread state:
00:10:29: Thread fast_thread: Empty
00:10:29: Thread todothread: Empty
00:10:29: Thread slow_thread: EmptyPQUICC_FEC(0/0): PHY 0 Read reg = 0 val = 1000
PQUICC_FEC(0/0): PHY 0 Read reg = 11 val = 588
PQUICC_FEC(0/0): PHY 0 Read reg = 4 val = 1E1
PQUICC_FEC(0/0): PHY 0 Wrote reg = 4 val = 1E1
PQUICC_FEC(0/0): PHY 0 Wrote reg = 0 val = 1000
PQUICC_FEC(0/0): PHY 0 Read reg = 12 val = 62
PQUICC_FEC(0/0): PHY 0 Wrote reg = 12 val = 62
Any ideas? I tried google, but everything came up in foreign languages ;)
My goal is to ping an ip like 4.2.2.2 from the console on my router (not even a computer on my local network) ;)
What am i missing?
Bronze
Re: First post and hopefully seaking some help... Cisco 1700 + D
Use the command Show ip route. See the IP routing table entries and find the IP addresses are showing or not. The following URL will help you:
http://www.cisco.com/en/US/docs/routers/access/1700/1701/software/configuration/guide/1700swcg.html
http://www.cisco.com/en/US/products/hw/routers/ps221/products_installation_and_configuration_guides_list.html
Hall of Fame Super Gold
You miss the pppoe commands under FA0.
configure under it:
pppoe enable
If still trouble, look at:
http://cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093fbf.shtml
Note: the commands mentioned in the document, beside the two above given, are not really necessary anymore.
190
