04-01-2010 07:23 AM - edited 03-04-2019 08:00 AM
Solved! Go to Solution.
04-02-2010 06:15 AM
Hi Jon, here you are...
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
memory-size iomem 10
ip subnet-zero
ip dhcp excluded-address 192.168.2.1
ip dhcp pool firewall
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 212.23.3.100 212.23.6.100
call rsvp-sync
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address dhcp
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip nat inside source list 101 interface FastEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
no cdp run
dial-peer cor custom
line con 0
exec-timeout 120 0
line aux 0
line vty 0 4
login
end
04-02-2010 06:18 AM
Alan
On interface fa0/1
remove the "ip address dhcp"
and add
ip address 192.168.2.1 255.255.255.0
Jon
04-02-2010 06:24 AM
Hi Jon,
Ok thats is done, and that is what I had about an hour ago..:)
What next boss
All the best from Alan
04-02-2010 06:25 AM
Alan
Not sure why you changed it ?
Try from PC1 connected to fa0/1 again.
Jon
04-02-2010 06:56 AM
Here you go Jon..
C:\Documents and Settings\Alan Walker>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : highforc-55aqzc
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8168C(P)/8111C(P) PCI-E G
igabit Ethernet NIC
Physical Address. . . . . . . . . : 00-1F-D0-27-A6-A7
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.2.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.2.0
DNS Servers . . . . . . . . . . . : 212.23.3.100
C:\Documents and Settings\Alan Walker>netstat -rn
Route Table
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 1f d0 27 a6 a7 ...... Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit Ether
net NIC - Packet Scheduler Miniport
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.2.0 192.168.2.2 20
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
169.254.0.0 255.255.0.0 192.168.2.2 192.168.2.2 30
192.168.2.0 255.255.255.0 192.168.2.2 192.168.2.2 20
192.168.2.2 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.2.255 255.255.255.255 192.168.2.2 192.168.2.2 20
224.0.0.0 240.0.0.0 192.168.2.2 192.168.2.2 20
255.255.255.255 255.255.255.255 192.168.2.2 192.168.2.2 1
Default Gateway: 192.168.2.0
Persistent Routes: None
arp -a showed no entries
04-02-2010 06:58 AM
Alan
That's better.
So can you access websites via URL ?
If so can you try setting PC2 to use DHCP and test with that one.
Jon
04-02-2010 07:02 AM
Hi Jon,
I did that before, and when you do an "show ip int br" the port comes up unassigned..
04-02-2010 07:34 AM
stewartrose wrote:
Hi Jon,
Sorry, you've lost me. What port ?
Jon
04-02-2010 07:39 AM
Hi Jon,
Ok what I have done is left a static ip on 0/1 port of Router, then switch everything of, and I do mean everthing, left it for 10mins
and brough each item back in turn, would you beleive it all now works, it is very slow to get to a website, but once you are on it, going though the pages is very fast, so I think ha ha, there is still a problem with the firewall, my next trick is to feed the router direct into the adsl router, nothing special it is an speedtouch 510 and bypass the firewall and see what happens..
Thank you again Jon, you have been a great help..
04-02-2010 07:46 AM
Alan
The speed could be duplex settings on your router. Check that everything is running full-duplex preferably at 100Mbps.
Glad we got there in the end
Please mark this post as solved.
Jon
04-01-2010 11:53 AM
Alan
What is 192.168.1.3 ?
Did you do the ping from 192.168.2.x PC ?
Jon
04-01-2010 11:58 AM
Hi Jon,
192.168.1.3 is my PC1 from the ASA
ASA |---- PC1 < this is what i am using talking to this forum
|----router-pc2 <---- i ping from here
con 0 <--- or here
04-01-2010 12:01 PM
So the ASA and internet connection is working from PC1 ?
If so can you add DNS servers manually to PC2 and then try and access the forum ?
Jon
