Webcast-Catalyst9k
Flash dies while applying QOS
This happened for couple of routers in a row which never happened before. I have been updating QOS policy on the router applying reload command. Since, I lost the connectivity with the routers I was thinking the router will reload with the old configs in 10 mins and will come online and started applying the same QOS on the other router. While updating QOS the second router also lost connectivity and i waited for 20 mins and both the router didn't come in online and atlast I came to know routers flash is dead.
It?s a 877 router with the IOS ?c870-advipservicesk9-mz.124-9.T?. Did any one have came across similar situation or is the ISO is a buggy version ?? It will be of great, if some one let me know.
Rajesh
Re: Flash dies while applying QOS
Hi Rajesh
you need to check the status of the remote router whether its stuck up in rommon mode or looping..
You can find out the exact reason once you get onto the console .
regds
Prem,
The remote router get strucks up in the rommon mode and its not looping.
Prem, i also don't understand what you mean by "You can find out the exact reason once you get onto the console" ?? Can you explain me better.
Rajesh
Hi Rajesh
Untill unless you have the access to the router you wont be able to find out the exact state of the router.
Since its not coming up the only way out there is to login onto the console through which you can identify whether your router is looping or on rommon mode.
Can you post the ios code which you are running in your box and also the ram/flash size installed in your router..
Also can you check out for the config register available and change it accordingly ?
regds
Prem,
I will be getting the router in couple of days. Then I will console and have a look and get the needed info you ware asking about. (Since, at the moment i was told that its going to rommon mode)
Anyhow thanks for your help and letz see how it goes.
Rajesh
Hi Rajesh,
I run into the same bug some time ago whilst running 124-4T2, please see the attached url;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddb41bb
I opened up a TAC and had to wait for a time until they had a fix for me.
If you upgrade to 124-9.T1 you should be OK as I am now running this IOS on my 877's with the service-policy applied to the dialer interface and all is OK.
If your router drops into ROM monitor and you are unable to boot from flash then you can always tftpdnld a new IOS into flash.
I got the router with me, when i consoled i am getting the following message. This happened to 3 routers in a row. With this output if some one has any idea kindly let me know.
System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
Copyright (c) 2005 by cisco Systems, Inc.
C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory
flashfs[0]: unable to allocate available block.
flash: file system initialization failed
Could not open boot directory: flash:/
Unable to open boot file
rommon 1 >
AFAIK you need to format the flas from the rommon prompt itself and need to upload the ios again.
Also find the below link which talks similar kinda problem..
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddc9f45
regds
Prem,
Already i formated the flash, and loaded the new IOS and its all fine now.
My concern is, while applying the QOS for remote sites and if the flash dies as it happened earlier its not good. I think you can understand what i mean.
Is there is any reason, why some of the router goes to rommon while applying QOS??? I was applying the similar QOS for all the remote sites (877 routers, IOS : c870-advipservicesk9-mz.124-9.T) and few got me to this problem.
Rajesh
Can you post the configuration of your router here ?
regds
Hi Prem,
I am have attached the QOS bit in which we experianced issues with the router flash memory.
class-map match-any VOIP
match precedence 5
match access-group 110
policy-map OUTBOUND
class VOIP
priority percent 50
class class-default
fair-queue
interface ATM0.1 point-to-point
description XXXXXX
bandwidth XXX
pvc 8/35
vbr-nrt XXX XXX 1
tx-ring-limit 3
encapsulation aal5mux ppp dialer
dialer pool-member 1
service-policy output OUTBOUND
interface Dialer1
bandwidth XXX
ip address negotiated
ip nat outside
no ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname XXXXXXXXXXXX
ppp chap password XXXXXXXXXXXX
Unless or otherwise specifically asked about this line "tx-ring-limit 3" we never use this.
Rajesh
243
