flooding of icmp-q in 3750 switch
The below output has taken from cisco 3750 switch which the cpu utilization is more than 80%. Can anybody help what is the meaning of this below inforamation.
switch#debug platform cpu-queues icmp-q
debug platform cpu-queue icmp-q debugging is on
Feb  6 18:44:09.860: ICMP-Q:Dropped redirect disabled on L3 IF: Local Port Fwding L3If:Vlan41 L2If:GigabitEthernet1/0/8 DI:0xB4, LT:7, Vlan:41   SrcGPN:8, SrcGID:8, ACLLogIdx:0x0, MacDA:0019.aade.0d58, MacSA: b8ac.6f2a.2734   IP_SA:10.43.41.87 IP_DA:172.20.31.25 IP_Proto:6
   TPFFD:ED580008_00290029_00B0009F-000000B4_90BD001F_6C6E1FC0
Feb  6 18:44:09.869: ICMP-Q:Dropped redirect disabled on L3 IF: Local Port Fwding L3If:Vlan41 L2If:GigabitEthernet1/0/8 DI:0xB4, LT:7, Vlan:41   SrcGPN:8, SrcGID:8, ACLLogIdx:0x0, MacDA:0019.aade.0d58, MacSA: 001f.d0e6.c09e   IP_SA:10.43.41.58 IP_DA:172.20.31.25 IP_Proto:6
   TPFFD:ED580008_00290029_00B00040-000000B4_C507001F_6C6E1FC0
Feb  6 18:44:09.869: ICMP-Q:Dropped redirect disabled on L3 IF: Local Port Fwding L3If:Vlan41 L2If:GigabitEthernet1/0/8 DI:0xB4, LT:7, Vlan:41   SrcGPN:8, SrcGID:8, ACLLogIdx:0x0, MacDA:0019.aade.0d58, MacSA: 001f.d0e7.1a26   IP_SA:10.43.41.61 IP_DA:161.69.13.141 IP_Proto:6
   TPFFD:ED580008_00290029_00B00042-000000B4_02E4001F_6C6E1FC0
Feb  6 18:44:09.869: ICMP-Q:Dropped redirect disabled on L3 IF: Local Port Fwding L3If:Vlan41 L2If:GigabitEthernet1/0/8 DI:0xB4, LT:7, Vlan:41   SrcGPN:8, SrcGID:8, ACLLogIdx:0x0, MacDA:0019.aade.0d58, MacSA: b8ac.6f21.659d   IP_SA:10.43.41.55 IP_DA:172.20.31.51 IP_Proto:6
   TPFFD:ED580008_00290029_00B00040-000000B4_DE38001F_6C6E1FC0
With regards,
Ashok
Hi Ashok,
The thing is that packets seems to come to VLAN 41 and should go out of the same inteface. When this happens router tries to generate ICMP redirect. I guess you "no ip redirect" configured on VLAN41. That stops router from sending ICMP redirect itself however due to ASIC logic it still sends those packets to CPU even is ICMP redirect are blocked.
So youy may need to check 2 things:
- check if VLAN 41 has "no ip redirects"  configured. Add it if that was not.
- check your design to stop packets from entering and leaving smae L3 interface
Nik
Dear Nik,
Thank you for your reply and please check the access list statments and vlan 41 configuration.
ip access-list extended MyLan_ACL
permit ip 172.26.0.0 0.0.255.255 10.42.150.232 0.0.0.7
permit ip 172.16.0.0 0.0.255.255 10.42.150.232 0.0.0.7
permit ip 10.43.41.0 0.0.0.255 10.43.41.0 0.0.0.255
permit ip 10.43.41.0 0.0.0.255 10.43.2.0 0.0.0.255
permit ip 10.43.41.0 0.0.0.255 10.43.4.0 0.0.0.255
permit ip 10.43.41.0 0.0.0.255 10.43.5.0 0.0.0.255
permit ip 10.43.41.0 0.0.0.255 10.42.2.0 0.0.0.255
permit ip 10.43.41.0 0.0.0.255 10.42.4.0 0.0.0.255
permit ip 10.43.41.0 0.0.0.255 10.42.5.0 0.0.0.255
permit ip 10.43.41.0 0.0.0.255 10.41.2.0 0.0.0.255
permit ip host 10.43.41.133 host 10.42.100.15
permit ip host 10.43.41.54 host 10.42.60.210
permit ip 10.43.41.0 0.0.0.255 10.41.4.0 0.0.0.255
permit ip 10.43.41.0 0.0.0.255 10.41.5.0 0.0.0.255
permit ip 10.43.41.0 0.0.0.255 host 10.42.60.23
permit ip 10.43.41.0 0.0.0.255 10.42.150.232 0.0.0.7
permit ip host 10.43.41.71 host 10.42.150.235
permit ip host 10.43.41.57 host 10.42.78.18
permit ip host 10.43.41.124 host 10.42.150.44
deny   ip 10.43.41.0 0.0.0.255 10.43.0.0 0.0.255.255
deny   ip 10.43.41.0 0.0.0.255 10.40.0.0 0.0.255.255
deny   ip 10.43.41.0 0.0.0.255 10.41.0.0 0.0.255.255
deny   ip 10.43.41.0 0.0.0.255 10.42.0.0 0.0.255.255
permit udp any any eq bootpc
permit udp any any eq bootps
permit ip 10.43.41.0 0.0.0.255 any
interface Vlan41
description ***MyLan_Vlan***
ip address 10.43.41.254 255.255.255.0
ip access-group MyLan_ACL in
ip helper-address 10.43.2.153
ip helper-address 10.43.5.221
ip helper-address 10.43.2.20
ip helper-address 10.43.2.159
no ip redirects
no ip unreachables
no ip proxy-arp
ip policy route-map PBR_Vlan41
Thank you,
With regards,
Ashok.
ACL is not a problem - you need to check routing "show ip route" for these destinations:
172.20.31.25
161.69.13.141
If the destination is same VALN 41 then that explains why packets getting to CPU. They are received and sent out of the same L3 interface. Router is designed to send ICMP redircect  and send copy of each such packet to CPU. Even with no ip redirect configured packets are still sent to cpu according to HW design.
You need to change your netwrok design to avoid these packets to come to this switch if those really coming and leaving on same VLAN 41.
Nik
1995
