11-15-2011 04:26 AM - edited 03-04-2019 02:17 PM
Dear all,
We suddenly noticed high CPU utilization on one of our 7600 routers. I output of show process CPU showed high utlization for the FM core process. I looked it up but did not find information on what this process does.
core-4#sh processes cpu sorted
CPU utilization for five seconds: 99%/11%; one minute: 88%; five minutes: 55%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
378 78448 984 79723 87.77% 16.14% 6.11% 0 FM core
231 1804 6526 276 0.16% 0.20% 0.16% 0 IP Input
225 208 984 211 0.08% 0.02% 0.01% 0 ADJ resolve proc
I appreciate any feedback on this.
Thank you,
Fabienne.
Solved! Go to Solution.
11-17-2011 07:38 PM
This FM core process is responsible from translating the access-list/PBR
and move this into a format that can be used to program this into the TCAM for traffic-processing.
I see that is not consistently High but spiking:
So it makes me think that you have quite long ACLs used for route-maps so when new updates are coming those ACLs are trigered and FM core start to work heavily. Am I right? If there is a chance to optimize ACL in the config or used Named ones if not already?
Nik
11-17-2011 07:38 PM
Nik
11-18-2011 12:45 AM
Thank you Nik,
We had recently configured PBR on the router with a new ACL, we shortened the ACL and removed uneeded entries. The CPU is now back to normal.
Thanks again.
11-18-2011 06:40 AM
Good News!
If possible you can mark my answer as correct one for others to be able to use in future.
Nik
11-18-2011 06:51 AM
Done:)
