07-03-2012 08:47 AM - edited 03-04-2019 04:52 PM
Due to departure of our IT guru I am left to manage our Cisco appliances so please excuse my poor basic knowledge, hopefully this site will help that improve!
I need to forward traffic from an Amazon server to an internal server with a SQL database on it so need to forward TCP 1433 to an internal IP (192.168.252.43) I have created an access rule to allow the amazon IPP through on 1433 but I am unsure how to point the traffic to the SQL server on the LAN.
I expect I will need to create a NAT rule to do this but cannot see how to achieve it.
I have another problem concerning a site to site VPN which establishes OK but does not pass traffic, I will post that question separately.
Any assistance would be gratefully received.
Dave
07-03-2012 09:57 AM
What version of code are you running on the 5510? Issue the "sh ver" command to determine.
James
07-04-2012 02:09 AM
Hi James, thanks for your reply, the result of the command: "sh ver" is below - hope you can assist
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(3)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
Fusion-FW02 up 10 days 18 hours
Hardware: ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is d0d0.fd1d.5b64, irq 9
1: Ext: Ethernet0/1 : address is d0d0.fd1d.5b65, irq 9
2: Ext: Ethernet0/2 : address is d0d0.fd1d.5b66, irq 9
3: Ext: Ethernet0/3 : address is d0d0.fd1d.5b67, irq 9
4: Ext: Management0/0 : address is d0d0.fd1d.5b68, irq 11
5: Int: Not used : irq 11
6: Int: Not used : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
SSL VPN Peers : 2
Total VPN Peers : 250
Shared License : Disabled
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions : 2
Total UC Proxy Sessions : 2
Botnet Traffic Filter : Disabled
This platform has an ASA 5510 Security Plus license.
