Community Member
Forward Voice & Data over two separate WAN cicuit
Does anybody know how to configure CIsco1841 to forward data and voice traffic over two separate WAN links. ( two physical interfaces are involved)
For example....
Data traffic should leave via fa0/0 (SDSL circuit)
Voice traffic should leave via fa0/1 (ADSL circuit)
Phones and PC's are connected to layer 2 switch.Do I need to create 2 VLANs ( voice & data) for is there any other method of doing it.
In case of circuit failure traffic should route to the other interface and should revert back when circuit come back up again.
Salman
Hall of Fame Super Silver
Re: Forward Voice & Data over two separate WAN cicuit
Hello Salman,
I make the assumption there is a router on the remote site where the two DSL links are terminated.
using two different Vlans/IP subnets provide additional benefits (true QoS treatment up to L2 switch port becomes possible).
However, it is not strictly required.
The right tool to perform routing decisions on criteria different from simple destination address is called PBR= policy based routing.
Using a route-map traffic received on interface is examined and it can be diverted to one link or to the other.
So you need to define an ACL that define what is VoIP traffic including VOIP signalling and RTP bearer streams.
Example
route-map pbr_voip_data permit 10
match ip address voice_traffic
set interface fas0/0
route-map pbr_voip_data permit 20
set interface fas0/1
you still have two static routes for each IP subnet that is beyond the two WAN links
ip route 10.10.10.0 255.255.255.0 fas0/0
ip route 10.10.10.0 255.255.255.0 fas0/1
ip route 10.10.20.0 255.255.255.0 fas0/0
ip route 10.10.20.0 255.255.255.0 fas0/1
to build a smart solution that can detect failures you need to refer to reliable static routing
see
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Actually the same approach can be used to verify reachability of next-hops in the route-map used by PBR.
Edit:
if you don't have a router at remote site but only a L2 switch and terminating modems for DSL connections:
you can get separation of traffic by using two different vlans/IP subnets and using modems as bridges.
However, if one link fails the other one cannot take over.
On the other end if each link is a L2 trunk carrying both vlans you would need to use IRB on router but it doesn't support per vlan STP so you would end with one link used for both types of traffic and one for backup only.
Hope to help
Giuseppe
Community Member
Thanks for the reply.
I understood what you have explained, but I don''t understand is how I can identify voice traffic using ACL.
Do you have any sample config which identify all voice traffic ( SIP, RTP, UDP etc).
Many thanks
Salman
173
