05-28-2008 06:22 AM - edited 03-03-2019 10:08 PM
Is there another way to make int. s0/0 with authentication behave as a backup to a frame relay connection?
By design, the interface won't activate because the s0/0 ppp int. doesn't have X.25 encap.
What other method can be utilized???
Thanks.
06-03-2008 11:02 AM
The Cisco Frame Relay implementation currently supports routing on IP, DECnet, AppleTalk, XNS, Novell IPX, CLNS, Banyan VINES, and transparent bridging.
Refer the following url for information on Frame relay configuration:
http://www.cisco.com/en/US/docs/ios/12_1/wan/configuration/guide/wcdfrely.html#wp1000943
Refer the following url for exaples on Frame-Relay configuration:
http://www.cisco.com/en/US/docs/ios/12_1/wan/configuration/guide/wcdfrely.html#wp1003004
