FR + QoS
when configure qos on FR interface.
RSVP, LLQ, Fragments, need to configure frame relay traffic shapping at the same time.
then how about CBWFQ, WRED ? is these also need FRTS?
i dont ask optimal,,i am asking need or not..
thanks
Silver
Re: FR + QoS
Yes.. Its needed.
CBWFQ on Frame Relay interfaces is always in the context of Frame Relay TS. You cannot use CBWFQ with Generic Traffic Shaping (GTS).
Re: FR + QoS
how about WRED,?
can we say that every QoS on FR need FRTS?
Re: FR + QoS
The type of QOS choice depends upon the underlying applications, WAN protocol, WAN topology, bandwidth restrictions etc.
WRED is always not a good idea as it drops packets. This is definitely not good for VOIP (if you are using it over your FR network). CBWFQ with Priority queueing (LLQ) is good for prioritizing voip, at the same time ensureing CBWFQ for rest of the data traffic.
FRTS is particularly required if you have a hub and spoke topology with restricted bandwidth at the hub or remote. Adding CBWFQ in addition to FRTS will ensure that bandwidth is guaranteed for each class of traffic during congestion. Again if you dont run a lot of mission critical apps, across the link, you dont need to use CBWFQ. IF your service provider doesnt drop traffic, you dont need to put FRTS on your routers to control the rate at which the router sends traffic to the cloud.
Re: FR + QoS
Hi..
Particulary, what i am asking is..
map-class class1
match ip add ...
policy-map qos
class class1
bandwidth 100
interface serial 0/0
encapsulation frame-rely
service out qos
is this working or not?
policy-map wred
class class-default
bandwith 100
randon-detect
interface serial 0/1
encapsulation frame-relay
service out wred
is this working?
Silver
Re: FR + QoS
both will work provided if u enable frts.
Re: FR + QoS
what I am asking is,,,WHAT IF WITHOUT FRTS..is working?
Re: FR + QoS
Your configuration will not work as listed for Frame Relay. To apply the policy, you have to apply it to a Frame Relay map-class. You can use the following document as a reference:
http://www.cisco.com/warp/public/125/cbwfq_17920.html
Your first config would need to look like:
class-map class1
match ip add ...
policy-map qos
class class1
bandwidth 100
class class-default
bandwidth 100
randon-detect
frame-relay interface-dlci ...
class FRTS
map-class frame-relay FRTS
service out qos
This configuration still wouldn't necessarily work the way you need it to. You need to include the various Frame-Relay parameters for CIR, Bc, etc. Notice that I included WRED by combining both configs.
HTH,
JW
Justin White, CCIE #14745, MCSE
whitej@gmx.net
Re: FR + QoS
Hi justin,
I am very thank you for your response, but i am not clear yet about my issues. you said to apply the policy, have to apply it to a Frame Relay map-class.
first, for frame-relay map-class, FRTS is madantory, and you missed it.
sencond, if to apply it to PVC, we would need FR map-class and FRTS,
third, what if to apply it to interface, I think don't need FRTS, this is bottom line.
thanks
Re: FR + QoS
Well, this is certainly equal opportunity, since the class-map is invalid too. Statement should be "match access-group", not "match ip address".
As to your third point, yes you can apply the service-policy directly to the interface. But you will not be able to affect a single PVC without FRTS. Applying your policy to the entire interface affects all DLCIs. You could place the DLCI on a subinterface to apply the policy there.
Also, as a point of reference, you should have a bandwidth statement on the Serial0/0 interface to use MQC accurately.
114
