Webcast-Catalyst9k
FR traffic shaping on FR switch!!
Hi all
In a lab environment I want to test Frame Relay traffic shaping between two routers, I am using a Cisco router as a frame relay switch which is configured as needed to allow FR connections (device type and static routing) BUT the issue is that I cannot find any documentation about how to configure FR traffic shaping parameters (CIR,...) to simulate FR Telco envirement.
Think you in advance.
Silver
Re: FR traffic shaping on FR switch!!
Hi Jack,
Think you for your response, but those links are about how to configure FRTS on CPE not on the Telco equipments.
For example i want to fix a limit to CIR on the frame relay as an ISP would do on a real FR envirement.
Think you!
Silver
You 're welcome and correct that PTT will setyp the PVC/SVC w/ BW limitation at their side. The FRTS in CE is used to prevent the package drop when there is burst traffic. It is not the same as PTT FR service. ;)
142
