Frame Relay Actual speed
hello,
can someone help on how i can get the real-time speed of frame relay in cisco routers? what is the exact command?
tnx!
1 REPLY
Hall of Fame Super Bronze
Re: Frame Relay Actual speed
If you want to know how much traffic the link is using at that moment, you can type show interface serial x/x and see the input/output rate stats.
By default the interval capture is 5 minutes, you can change this behavior to 30 seconds by entering the following command under the interface:
load-interval 30
95
