Frame Relay - Basic Configurations Hub and Spoke
Hello Everybody..
I am trying to set up a frame-relay hub & spoke topology in my home lab. I have two Cisco 2610XM with one of them got a Serial NM-4A/S 4 serial ports async/sync and this would be my FRS router.
My question is how do I connect them physically back to back with a DB60 DTE/DCE cable to make them a hub and spoke network. The idea is to run frame-relay over OSPF NBMA network.
Here is my current connection:
R1_HUB
Cont t
Interface serial 1/0
ip address 172.12.123.1 255.255.255.0
clockrate 56000
encapsulation frame-relay
frame-relay map ip 172.12.123.2 dlci 122 b
frame-relay map ip 172.12.123.3 dlci 123 b
no frame-relay inverse-arp
R2_SPOKE
Conf t
Interface serial 0/0
ip address 172.12.123.2 255.255.255.0
frame-relay map ip 172.12.123.1 dlci 221 b
frame-relay map ip 172.12.123.3 dlci 221 b
R3_SPOKE
conf t
ip address 172.12.123.3 255.255.255.0
frame-relay map ip 172.12.123.1.dlci 321 b
frame-relay map ip 172.12.123.2 dlci 321 b
Thank you for your time and help!
Message was edited by: arif datau
1 REPLY
Hi Arif(I hope this is your good name?)
you connect them back-to-back indeed, set DCE side to do clocking, on the FRS guy issue 'frame-relay switching' in global mode, then issue frame-relay routes between interfaces.
while checking the command I found this excerpt that might be of some help for you:
http://www.ciscopress.com/articles/article.asp?p=170741&seqNum=7
HTH.
1712
