11-03-2011 04:36 PM - edited 03-04-2019 02:09 PM
Hi All,
I have 2 routers back-to-back in my lab. I'm trying to configure Frame Relay. For now I'm just trying to ping from 12.1 to 12.2 but it's not working. The serial interfaces on both routers are up and up. And prior to implementting Frame Relay my pings were successful.
Does this look correct, or do you see something out of place?
ROUTER 1:
interface Serial1
ip address 192.168.12.1 255.255.255.0
ip nat inside
encapsulation frame-relay
no keepalive
frame-relay map ip 192.168.12.2 63
ROUTER 2:
interface Serial0
ip address 192.168.12.2 255.255.255.0
no ip directed-broadcast
no keepalive
clockrate 56000
frame-relay map ip 192.168.12.1 65
Solved! Go to Solution.
11-03-2011 05:20 PM
try to make your config exactly as below and try it
ROUTER 1:
interface Serial1
no ip nat inside
no keepalive
frame-relay map ip 192.168.12.2 63 broadcast
ROUTER 2:
interface Serial0
no keepalive
clockrate 56000
frame-relay map ip 192.168.12.1 63 broadcast
then do
show frame-relay map and make sure it is up
hope this help
if helpful Rate
11-03-2011 05:20 PM
ROUTER 1:
interface Serial1
no ip nat inside
no keepalive
ROUTER 2:
interface Serial0
no keepalive
clockrate 56000
then do
hope this help
if helpful Rate
11-03-2011 05:24 PM
Thank You !! It's working now. The problem was the DLCI. I made them both the same. I thought they could be different, but I guess that's not the case in p-t-p connection. I rated you, I think. Let me know if not. Thanks again.
