Community Member
frame-relay class question
Let's say that I have a frame-relay class like this:
frame-relay adaptive-shaping becn
frame-relay fecn-adapt
frame-relay cir 256
frame-relay mincir 192000
What's happening if I apply this using the command
frame-relay traffic-shaping
frame-relay class MYCLASS
on interface serial0 where I've got 4 subinterfaces set?
Is 256/192 going to be the cir/mincir for each subinterface? Or will this bandwidth be the maximum (sum) between subinterfaces?
Thanks to read!
1 REPLY
Blue
Re: frame-relay class question
the frame-relay class will apply to the interface effectively setting the cir/min as described above for the entire interface, not each sub-interface. (do not believe the subInterfaces will see this as their capabilities)
(this will be the maxium sum between interfaces) as you've put it.
you should put the frame-relay traffic-shaping on the interface and the frame-relay class maps on the subinterfaces to achieve what it sounds like you want.
ie:
interface Serial0/0
no ip address
encapsulation frame-relay
no fair-queue
interface Serial0/0.1 point-to-point
ip address 10.1.1.1 255.255.255.0
frame-relay interface-dlci 16
frame-relay class XXX
map-class frame-relay XXX
frame-relay cir 256000
90
