FRAME RELAY DDR ISDN
lgurley
The only way we can get our DDR to come up is to do a shutdown on both ends of our frame relay serial interfaces. The dialing ends config looks like this.
hostname Denton
logging buffered 4096 debugging
enable secret 5 <gone>
enable password 7 <gone>
username FLOWAN1 password 7 <gone>
ip subnet-zero
ip cef
no ip domain-lookup
no ip dhcp conflict logging
isdn switch-type basic-dms100
isdn voice-call-failure 0
modemcap entry MyMultitech:MSC=&FS0-1&C4&D3$SB115200
interface FastEthernet0/0
ip address 75.75.188.110 255.255.255.0
ip access-group 115 in
ip access-group 115 out
no ip directed-broadcast
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
interface Serial0/0
description Connected to Internet T1
bandwidth 512
no ip address
encapsulation frame-relay
no ip mroute-cache
no fair-queue
service-module t1 timeslots 1-8
service-module t1 fdl both
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
bandwidth 512
ip address 75.75.97.17 255.255.255.252
no ip mroute-cache
frame-relay interface-dlci 100
interface BRI0/0
ip address 192.168.1.2 255.255.255.0
encapsulation ppp
no ip mroute-cache
load-interval 30
no keepalive
dialer idle-timeout 170
dialer map ip 192.168.1.1 name FLOWAN1 12294300357
dialer map ip 192.168.1.1 name FLOWAN1 12294300359
dialer hold-queue 10
dialer-group 1
isdn spid1 94038376660101 3837666
isdn spid2 94038323310101 3832331
no fair-queue
no cdp enable
ppp authentication chap
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 75.75.97.18
ip route 0.0.0.0 0.0.0.0 192.168.1.1 150
ip route 10.99.99.99 255.255.255.255 BRI0/0
no ip http server
map-class dialer BRI
logging 75.75.1.4
access-list 101 remark Intersting Traffic Definition for Backup Link
access-list 101 permit ip any any
access-list 115 deny udp any any eq tftp
access-list 115 deny tcp any any eq 135
access-list 115 deny udp any any eq 135
access-list 115 permit ip any any
access-list 115 deny tcp any any eq 445
access-list 115 deny tcp any any eq 5554
dialer-list 1 protocol ip list 101
line con 0
exec-timeout 5 0
password 7 <gone>
login
transport input none
line aux 0
modem autoconfigure type MyMultitech
line vty 0
password 7 <gone>
login
line vty 1 4
password 7 <gone>
login
end
ankurbhasin
Level 9
Level 9
Hi Friend,
You config makes me feel your primary and backup interface are on same router.
Now you have to define on your primary what is the condition which can bring the backup interface up which is your BRI interface.
Define
backup interface bri0 --- under serial sub interface which is for frame relay
Check this link out
http://www.cisco.com/warp/public/793/access_dial/britobribackup.html
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a008009457d.shtml
Ankur
Am I correct in assuming that your sub-interface never goes down when the other end fails ? If so, "backup interface" on this end won't help you either. Perhaps Frame Relay End to End Keepalive or Dialer Watch might do the trick for you.
Larry
Do I understand correctly that if you just shut down the frame relay interface on the local router that DDR does not start up? Does it really require shutting down the remote router interface as well?
There are several approaches that can be taken for implementing DDR. Your approach of floating static routes is quite common, backup interface is another traditional implementation. I find Backup Interface to be a bit more restrictive (it dedicates the dialing interface so that it can not be used for anything else.) and would probably look for other solutions in your situation. Dialer Watch is somewhat newer and since it looks like there would be only connected routes and the one static default route, I am not sure that Dialer Watch would be a whole lot better that what you are doing.
As I look at your config it looks like that if the static default route is withdrawn that the floating static should kick in and initiate DDR (assuming that there is interesting traffic). I am puzzled why shut down of the local interface does not remove the default route and initiate DDR. I would think that shutting down either the physical serial interface or the subinterface should be enough to start DDR.
Rick
Rick
