Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Frame Relay in a Lab and Addressing
For some time I've been trying to get a simple FR point-to-point link to work in a lab over a back-to-back cable. I had different DLCIs configured on the two subinterfaces on opposite ends of the link, and the DTE end always indicated that the PVC had been deleted.
Now I've configure the same DLCI on both ends of the link, and the connection works.
Is this unique to a lab setting, or have I been misunderstanding "normal" FR addressing?
Eric Hines
1 ACCEPTED SOLUTION
Re: Frame Relay in a Lab and Addressing
Thanks. This doc and its companion (linked to in this doc) will be very useful to this newbie.
Eric Hines
Hall of Fame Super Silver
Eric
When you are in a lab situation where the routers connect directly back to back with no Frame Relay switch then the DLCI must be the same on both routers. In a normal Frame Relay implementation where the router connects to a Frame Relay switch to connect to the other router then the DLCIs can easily be different in the routers.
Rick
Eric Hines
134
