01-09-2008 01:21 PM - edited 03-03-2019 08:12 PM
Hello Guys,
I am attempting configure Frame Relay on my 2 router. I have 2 serial cards only. Evidently I am not doing something right. I need to know if anyone has any documentation on how to configure a point to point using Frame Relay between 2 routers? Thanks. I have tried and can't PING HELP!!!
01-09-2008 01:29 PM
You should be able to get here few FR scenario configurations.., if no success you may need to post more config info from both routers.
http://www.cisco.com/en/US/tech/tk713/tk237/tech_configuration_examples_list.html
Rgds
Jorge
01-09-2008 01:40 PM
Charlie
I am not sure from your post whether you are trying to configure routers with a real serial link as Frame Relay or if you are are trying to configure routers back to back as Frame Relay. Since the configuration of a real serial link is easy and examples abound I am assuming that you are trying to do it back to back. It has been a while since I have done that, but my memory is that you need to configure both interfaces as encapsulation frame-relay, you need to configure both interfaces to use the same DLCI, and you need to configure the interfaces with no keepalive (since you do not have anything to generate LMI and LMI is the essential part of keepalives in Frame Relay). Of course you also need to take care of things like clock-rate on the router that will be the physical DCE.
Rick
01-09-2008 01:46 PM
I am attempting to configure a back to back.
Router2
config
Current configuration : 590 bytes
version 12.3
hostname Router2
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/2/0
no ip address
frame-relay lmi-type ansi
interface Serial0/2/0.123 point-to-point
ip address 192.168.1.2 255.255.255.252
frame-relay interface-dlci 122
interface Serial0/2/1
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line vty 0 4
login
end
Router1 config
Current configuration : 608 bytes
version 12.3
hostname Router1
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 56000
interface Serial0/2/0.122 point-to-point
ip address 192.168.1.1 255.255.255.252
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line vty 0 4
login
end
01-09-2008 01:51 PM
Charlie
The biggest issue that I see is the
under both serial interfaces. Since there is nothing in your back to back connection that will generate LMI, you have told your routers to expect to receive ANSI LMI and when they do not receive it the line protocol stays down. Try removing the frame-relay lmi-type ansi and confiure no keepalive and see what happens.
Rick
01-09-2008 01:56 PM
That did it. Thanks Rick.
