08-22-2008 02:48 PM - edited 03-03-2019 11:14 PM
Hello all!
I have 2 routers, each router has 2 x E1 cards and they are connected back-to-back.
If I configure each pair of E1 individual, with FR everything works fine. I bundle the E1 interfaces into a FR multilink, the MFR interface is UP, multilink is reported UP, but no traffic is passing through it. Everything seems to be fine, but (for example) I cannot ping between this 2 routers.
The strange fact is that when I issue "sh frame-relay pvc" there are no INPUT packets. Debugging is showing me only sent packets.
I changed the frame-relay encapsulation (Cisco / IETF), tried different scenarios / parameters, change MTU size...nothing helped so far.
Do you have any idea, advice for me?
Thanks a lot!
Cheers,
Calin
Solved! Go to Solution.
08-26-2008 02:10 AM
Hello Calin,
it was the no arp frame-relay.
you used LMI keepalive with one side as DCE.
Nice to hear you solved the issue
about the solved symbol only you could set it on someebody else's answer because you have started the thread.
Best Regards
Giuseppe
08-22-2008 10:08 PM
Hello Calin,
use the following link as a reference:
http://www.cisco.com/en/US/docs/ios/12_2s/feature/guide/fs_mfr.html
on the physical interfaces you need
encapsulation frame-relay mfr
To create a multilink Frame Relay bundle link and to associate the link with a bundle, use the encapsulation frame-relay mfr command in interface configuration mode. To remove the bundle link from the bundle, use the no form of this command.
encapsulation frame-relay mfr number [name]
no encapsulation frame-relay mfr number [name]
Example:
interface mfr0
interface serial 0
encapsulation frame-relay mfr0 BL1
Hope to help
Giuseppe
08-23-2008 03:21 AM
Hello Giuseppe and thanks for replying.
I believe that I have the configuration OK. I's my fault, I should paste it here, to give you some more information. So here it is:
interface Serial1/0
description -> R1 s1/0
no ip address
encapsulation frame-relay MFR1
serial restart-delay 0
no dce-terminal-timing-enable
no arp frame-relay
frame-relay multilink lid R2_S10
interface Serial1/1
description -> R1 s1/1
no ip address
no arp frame-relay
frame-relay multilink lid R2_S11
interface MFR1
description -> bundle R1
no ip address
no keepalive
frame-relay multilink bid R2
interface MFR1.1 point-to-point
ip address 192.168.0.2 255.255.255.0
frame-relay interface-dlci 101
and the same on the other side.
Also:
R2#sh frame-relay multilink
Bundle: MFR1, State = up, class = A, fragmentation disabled
BID = R2
Bundle links:
Serial1/1, HW state = up, link state = Up, LID = R2_S11
Serial1/0, HW state = up, link state = Up, LID = R2_S10
but I cannot ping the other end :(
Thanks and cheers,
Calin
08-23-2008 03:54 AM
Hello Calin,
i would try on one side:
int mfr 1
keepalive
frame-relay intf-type dce
on the other router
int mfr1
keepalive
Just to see if there is any changes
May you post the sh frame-rel map .
After having reenabled keepalive with one side acting as the switch view with sh frame-rel lmi if you get bidirectional communication.
see
Example:
Router(config-if)# frame-relay intf-type dce
Configures a device to function as the data circuit-terminating equipment (DCE).
â¢Only one end of a link should be configured as the DCE. The other end will function as the data terminal equipment (DTE), which is the default setting.
â¢This command can be used only if Frame Relay switching has been enabled by entering the frame-relay switching command in global configuration mode.
I know that on back to back single link disabling keepalive is effective to get a working link I'm not sure it is the same with multilink FR.
Hope to help
Giuseppe
08-23-2008 05:29 AM
Hi Giuseppe!
Thanks again for replying!
Above you have some info when the "no keepalive" was in place
sh frame-relay pvc
PVC Statistics for interface MFR1 (Frame Relay DTE)
Active Inactive Deleted Static
Local 0 0 0 1
Switched 0 0 0 0
Unused 0 0 0 0
DLCI = 101, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE = MFR1.1
input pkts 0 output pkts 1021 in bytes 0
out bytes 325865 dropped pkts 0 in pkts dropped 0
out pkts dropped 0 out bytes dropped 0
in FECN pkts 0 in BECN pkts 0 out FECN pkts 0
out BECN pkts 0 in DE pkts 0 out DE pkts 0
out bcast pkts 951 out bcast bytes 318585
pvc create time 1d02h, last time pvc status changed 15:20:47
-as you can see there are no "input packets" on DLCI 101.
sh frame-relay map
MFR1.1 (up): point-to-point dlci, dlci 101(0x65,0x1850), broadcast
-this seems fine
NOW after modifying according to your advice (keepalive enable, DTE-DCE...):
R1(DCE)
sh frame-relay pvc
PVC Statistics for interface MFR1 (Frame Relay DCE)
Local 0 1 0 0
Switched 0 0 0 0
Unused 0 0 0 0
DLCI = 101, DLCI USAGE = LOCAL, PVC STATUS = INACTIVE, INTERFACE = MFR1.1
input pkts 0 output pkts 1026 in bytes 0
out bytes 327540 dropped pkts 0 in pkts dropped 0
out bcast pkts 956 out bcast bytes 320260
pvc create time 1d02h, last time pvc status changed 00:04:49
sh frame-relay map
MFR1.1 (down): point-to-point dlci, dlci 101(0x65,0x1850), broadcast
status defined, inactive
sh frame-relay lmi
LMI Statistics for interface MFR1 (Frame Relay DCE) LMI TYPE = CISCO
Invalid Unnumbered info 0 Invalid Prot Disc 0
Invalid dummy Call Ref 0 Invalid Msg Type 0
Invalid Status Message 0 Invalid Lock Shift 0
Invalid Information ID 0 Invalid Report IE Len 0
Invalid Report Request 0 Invalid Keep IE Len 0
Num Status Enq. Rcvd 3 Num Status msgs Sent 3
Num Update Status Sent 0 Num St Enq. Timeouts 2545
---continues in next message (characters exceeded 4000) -------
08-23-2008 05:29 AM
---continuing-----
R2(DTE)
sh frame-relay pvc
Local 0 1 0 0
Switched 0 0 0 0
Unused 0 0 0 0
input pkts 0 output pkts 0 in bytes 0
out bytes 0 dropped pkts 0 in pkts dropped 0
out bcast pkts 0 out bcast bytes 0
pvc create time 00:00:28, last time pvc status changed 00:00:28
sh frame-relay map
sh frame-relay lmi
LMI Statistics for interface MFR1 (Frame Relay DTE) LMI TYPE = CISCO
Num Status Enq. Sent 9588 Num Status msgs Rcvd 0
Num Update Status Rcvd 0 Num Status Timeouts 9587
-on R2 seems that I have no sent / receive LMI packets
Now the MF1 is UP protocol DOWN.
I tried the steps above yesterday also, but I said let's give a shot today too.
Cheers,
Calin
08-24-2008 01:23 AM
Hello again!
So, nobody has any idea what can be wrong there?:(
Thanks again!
Cheers,
Calin
08-24-2008 10:13 PM
Sorry to push the things here, but anyone have any idea why I don't have input packets on the multilink interface?
Thanks!
Cheers,
Calin
08-24-2008 11:52 PM
Hello Calin,
I see this:
the DLCI is still inactive so LMI is not working correctly
sh frame-relay map
on R2 from sh frame-rel lmi (DTE)
on R1 from sh frame-rel lmi (DCE)
What releases of IOS and what routers are you using ?
it could be a bug of your release.
Cabling and clocking shoud be fine because the links are working when used in stand alone.
Now, with the configuration of FR LMI you have a confirmation that something is not working.
You can also use debug frame-rel lmi to see if you can see the LMI frames on the routers.
I had tested FR multilink on C7200 using two E1 ports of PA with 8 E1 with the LMI and it worked between two C7206.
I would verify with feature navigator and I would try another IOS release on one or both routers.
Hope to help
Giuseppe
08-25-2008 12:08 AM
Thanks Giuseppe for all help!
I will try your advices and let you know how is working.
Cheers,
Calin
08-25-2008 04:13 AM
Hello!
Giuseppe as I said I'm back with some more info.
I searched for IOS BUGs and features and everything is ok. Upgrading the IOS cannot be taken into consideration now, because of some environmental policies.
I tried ppp multilink instead of FR multilink, and it is working fine, but I cannot transport 2 VRF over this multilink interface because the physical interface can be bundled to only one multilink ppp group and for multiple VRFs I need at leat 2 MU interfaces.
The only thing that is in the Cisco documentation at Restrictions for FRF16.1 is: "The multilink Frame Relay peer device must not send frames that require assembly or reordering." but I have not idea how to check if I send this kind of frames, at this moment.
Thanks for support!
Cheers,
Calin
08-25-2008 04:25 AM
Hello Callin,
>> but I cannot transport 2 VRF over PPP multilink
is PPP multilink a VRF access link or a a backbone link ?
As a backbone link you just have to enable MPLS forwarding with MPLS IP.
As VRF access link do the following :
define subinterface of the PPP multilink and associate one with VRF1 and one with VRF2.
I was able to define subinterfaces of a PPP interface.
Hope to help
Giuseppe
08-25-2008 05:18 AM
Regarding:
"I was able to define subinterfaces of a PPP interface."
I could not define subinterfaces:
(config)#int multilink ?
<1-2147483647> Multilink interface number
(config)#int multilink 1 ?
(config)#int multilink 1.1
% Invalid input detected at '^' marker.
Maybe we are talking about different stuff.
Cheers,
Calin
08-25-2008 08:21 AM
Hello Calin,
I agree with you this solution is not possible for you
Best Regards
Giuseppe
08-25-2008 12:27 PM
Giuseppe thanks for all the help and support.
I still don't know yet how to "crack" this problem, but if I will find a solution be sure that I'll post it here.
Cheers,
Calin
