Frame-relay network with RIP route
here i have frame-relay network running RIP protocol, currently too many weird things happening in thise scneario.let see one by one,
First i make a frame-relay network all three router has end to end ip connectivity, after that i start rip protocol on all three routers but didn't see any router sending update by viewing debug ip rip cmd.i did google search some of them saying run rip on interface level and some other saying use neigbour cmd on hub router then running rip by interface level router1 (hub) start sending updates i did the same thing on r2 and r3  now both spoke router can able to ping hub router loop interface, but router1 not ping to spoke doesn't has any rip route .please help me to understand this problem.
R1# sh runn
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Serial1/0
encapsulation frame-relay
serial restart-delay 0
frame-relay map ip 192.168.1.3 103 broadcast
frame-relay map ip 192.168.1.2 102 broadcast
no frame-relay inverse-arp
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
router rip
version 2
network 1.0.0.0
network 192.168.1.0
no auto-summary
R2# sh runn
interface Loopback0
ip address 2.2.2.2 255.255.255.255
no ip address
shutdown
duplex half
interface Serial1/0
ip address 192.168.1.2 255.255.255.0
frame-relay map ip 192.168.1.3 201
frame-relay map ip 192.168.1.1 201
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
router rip
version 2
network 2.0.0.0
network 192.168.1.0
no auto-summary
ip forward-protocol nd
no ip http server
R3#sh runn
interface Loopback0
ip address 3.3.3.3 255.255.255.255
no ip address
shutdown
duplex half
interface Serial1/0
ip address 192.168.1.3 255.255.255.0
frame-relay map ip 192.168.1.2 301
frame-relay map ip 192.168.1.1 301
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
router rip
version 2
network 3.0.0.0
network 192.168.1.0
no auto-summary
no ip http server
no ip http secure-server
R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     1.0.0.0/32 is subnetted, 1 subnets
C       1.1.1.1 is directly connected, Loopback0
C    192.168.1.0/24 is directly connected, Serial1/0
R2#sh ip rou
R       1.1.1.1 [120/1] via 192.168.1.1, 00:00:01, Serial1/0
     2.0.0.0/32 is subnetted, 1 subnets
C       2.2.2.2 is directly connected, Loopback0
R3#sh ip rou
R       1.1.1.1 [120/1] via 192.168.1.1, 00:00:22, Serial1/0
     3.0.0.0/32 is subnetted, 1 subnets
C       3.3.3.3 is directly connected, Loopback0
1 ACCEPTED SOLUTION
Purple
split=horizon is disabled on a multipoint frame-relay physical interface and enabled on a multipoint frame-relay subinterface by default,it has no sense on a point-to-point subinterface. What split-horizon does is not sending updates out thesame interface they were received on.
So by default if you are using multipoint subinterfaces on the hub,the updates from one spoke won't get to the other spoke as split-horizon is enabled by default and you'll have to disable it with the no ip split-horizon command on the hub for each spoke to see the other spokes routes advertised by RIP.
The best design is to use point-to-point subinterfaces on all routers and you won't have to worry about static frame maps,split-horizon.
Regards.
Alain
Try adding "no ip split-horizon" on the interface that connects to the frame on R1 and see if you get your routes...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
yes now it's working, can you please tell me any other way to do this without disableing split-horizon.
Purple
Hi John,
Isn' split-horizon disabled by default on a physical Frame-relay interface ? In the config posted by OP the broadcast keyword is missing on the static mappings of the spokes.
Alain
Hi cadet alain,
i give broadcast command on all three routers after that rip start send updates also i enable rip on serial interface which directly connect to frame-realy switch.but now i understand how its work any why we need to disble split horizon on hub router
am very big confused what is the use of point to point and multipoint link i read one article they didn't disble split-horizon on point to point link and hub send updates to spoke to spoke.
It would be very helpful if you explain the use of point to point and multipoint links.
Purple
Regards.
Alain
thanks, if i use point to point sub interface have to use seperate subnet for each spoke. anyway i understand well am going to try point to point sub interface if i got any problem or doubt with this scenario i ll post in my next reply aslo i ll rate this post if it success . Thanks for your useful reply cadet.
745
