Frame-Relay not working on 2801 WIC
We are replacing existing 2610 routers with 2801's. The 2801 has a WIC-1DSU-T1-V2 out of about 400 sites, we have 10 that we cannot get the T1 interface to come up , out of AL. We have sent different 2801's to these sites and still cannot get the interface to come up. Anyone else have issues with this WIC in 2801's ??
Hall of Fame Super Bronze
Re: Frame-Relay not working on 2801 WIC
Can we see the config from the working 2610 that is being replaced by the 2801 ?
Can we also see the config applied to the 2801 ?
Do you have interface up/up, up/down or down/down ?
Are these partial or full T1s ?
Please issue 'show frame map'and 'show frame pvc' as well - then post it there.
Sure, I am attaching the configs. this is not a full T1, a frac. The interface is down/down. I do not have access to get the show commands from the 2801, the tech that was in the field has already left. But I do have the outputs from the 2610. Thanks.
2610 Serial Interface :
interface Serial0/0
no ip address
encapsulation frame-relay IETF
ip route-cache flow
no ip mroute-cache
priority-group 1
service-module t1 timeslots 1-4
service-module t1 fdl att
frame-relay lmi-type ansi
hold-queue 125 in
interface Serial0/0.1 point-to-point
description pvc to Rochester host 997
bandwidth 128
ip address 192.168.31.181 255.255.255.252
frame-relay interface-dlci 997 IETF
interface Serial0/0.2 point-to-point
description pvc to Rochester host 998
bandwidth 8
ip address 192.168.51.181 255.255.255.252
frame-relay interface-dlci 998 IETF
2801 Serial Interface:
interface Serial0/3/0
no ip address
no shutdown
service-policy output IPFRCOS
ip route-cache flow
no ip mroute-cache
hold-queue 125 in
interface Serial0/3/0.1 point-to-point
bandwidth 8
no shutdown
interface Serial0/3/0.2 point-to-point
bandwidth 128
no shutdown
interface Serial0/3/0.777 point-to-point
description *** Epvc to Rochester host 998 and 997 ***
bandwidth 256
ip address 192.168.71.181 255.255.255.252
no shutdown
frame-relay interface-dlci 777 IETF
2610 Show frame map:
Rtr201#sho frame map
Serial0/0.2 (up): point-to-point dlci, dlci 998(0x3E6,0xF860), broadcast, IETF
status defined, active
Serial0/0.1 (up): point-to-point dlci, dlci 997(0x3E5,0xF850), broadcast, IETF
Rtr201#
The output from the 2610 looks good and the sample config from the 2801 you posted should work.
Any alarms on the T1 when connecting the 2801 ?
I would like to see the 'show service-module' when the working 2610 is connected vs when the 2801 is connected.
Yes, the 2801 serial interface is in alarm. I will try to get the show service-module when i can get another tech out to the site to console in. Thanks.
269
