frame-relay on 2800
I have 3 Routers 2600 series each with 2FAST Ethernet.
I want to practise FRame-Relay is it possible.
What IOS would be required?
I have limited flash and memory ( 8MB Flash and 16MB Memory )
If Frame-relay is possible can you please advice an IOS that supports my router model and flash/memory
Re: frame-relay on 2800
You can make use of Feature Navigator to select the IOS required for your router which can fit onto your Flash/Memory..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
Hall of Fame Super Gold
you need serial ports (WIC-1T and few other types) and related cables to configure frame-relay.
The, all and any IOS images supports frame-relay.
Hope this helps, please rate post if it does
136
