frame-relay payload-compression
lgontarsk
Hi, does anyone know the difference between the packet-by-packet vs frf9stac parameters for this command?
Lisa G
aghaznavi
Level 5
Level 5
1.Payload compression on each VC consumes approximately 40 kilobytes for dictionary memory.
2.FRF.9 compression uses relatively higher compression ratios, allowing more data to be compressed for faster transmission. FRF.9 compression provides the ability to maintain multiple decompression/compression histories on a per-DLCI basis.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080fdc.html#wp1066773
aghaznavi
Level 5
Level 5
