12-03-2007 12:02 AM - edited 03-03-2019 07:45 PM
Hi all,
I have a problem with my Frame relay Connection. I have two subinterfaces one of them working properly and the other subinterface cant ping the remote site. The interface is up/up, but also it cant ping itself.
I get the follwoing Messages when i debug.
Any idea? Your Help is much appreciated. THANK!
2d02h: Serial0/0.18(o):Pkt sent on dlci 18(0x421),
NLPID 0x3CC(IP), datagramsize 64
2d02h: Serial0/0.18(o): dlci 18(0x421), NLPID 0x3CC(IP), datagramsize 104
2d02h: broadcast dequeue.
2d02h: Serial0/0.18(o): dlci 18(0x421), NLPID 0x3CC(IP), datagramsize 104.
2d02h: Serial0/0.18: broadcast search
2d02h: Serial0/0.18(o): dlci 18(0x421), NLPID 0x3CC(IP), datagramsize 64
Success rate is 0 percent (0/5)
south_kal#
12-03-2007 01:16 AM
Debug appears normal.
Pls send config for both routers.
12-03-2007 04:09 AM
Hi there,
Thanks for the response.
The Remote site is a Frame Relay Link going to Carrier provider Private Network
Router 1
interface Serial0/0.18 point-to-point
description Private link to XYZ
bandwidth 512
ip address 192.168.101.246 255.255.255.252
frame-relay interface-dlci 18
class XYZ
The head office router is Connected via a DSL line Connected to a the Carriers Private Network
Router 2
interface FastEthernet0/0/0
description XYZ Connection into LAN
ip address 192.168.101.245 255.255.255.252
ip access-group FE-000-IN in
ip access-group FE-000-OUT out
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
Both Ends are connected to the same Carriers Private network but with different WAN Technology.
12-03-2007 04:28 AM
either the ACLs are blocking pings, or there is a problem in MPLS cloud of SP.
In this sense it would be better if you coudl get a DSL interface on router 2, so that you can monitor and effectively utilize QoS.
