Frame relay problem
Hi there
i am trying to set up a frame relay hub and spoke enviroment in my home lab.I have three 2600 routers and one frame switch(2520).R1 is the hub
I have the s0/0 of R1 connected to s1 of FR switch.R2 has s0/0 coneected t0 S2 of FRS and R3 has s0/0 to S3 of FRS.
The conf on FRS is
frame-relay switching
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
no ip address
encapsulation frame-relay
logging event subif-link-status
logging event dlci-status-change
clockrate 56000
no frame-relay inverse-arp
frame-relay lmi-type cisco
frame-relay intf-type dce
frame-relay route 122 interface Serial2 221
frame-relay route 123 interface Serial3 321
interface Serial2
no ip address
clockrate 56000
frame-relay route 221 interface Serial1 122
interface Serial3
no ip address
clockrate 56000
frame-relay route 321 interface Serial1 123
< THE CONFIG on R1 HUB is >
interface Serial0/0
ip address 172.12.123.1 255.255.255.0
frame-relay map ip 172.12.123.2 122 broadcast
frame-relay map ip 172.12.123.3 123 broadcast
interface Serial0/1
no ip address
shutdown
no ip http server
ip classless
<THE CONFIG ON SPOKE R2 is >
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface FastEthernet0/0
ip address 172.23.23.2 255.255.255.224
duplex auto
speed auto
interface Serial0/0
no ip address
interface Serial0/0.123 multipoint
ip address 172.12.123.2 255.255.255.0
frame-relay map ip 172.12.123.1 221 broadcast
frame-relay map ip 172.12.123.3 221
THE CONFIG ON SPOKE R3 IS
nterface Loopback0
ip address 3.3.3.3 255.255.255.255
ip address 172.23.23.3 255.255.255.224
duplex auto
speed auto
interface Serial0/0
no ip address
no fair-queue
interface Serial0/0.31 point-to-point
ip address 172.12.123.3 255.255.255.0
frame-relay interface-dlci 321
interface Serial0/1
no ip address
shutdown
WHEN GO FRS AND RUN
SHOW FRAME ROUTE it gives output
2520-1#sh frame route
Input Intf Input Dlci Output Intf Output Dlci Status
Serial1 122 Serial2 221 inactive
Serial1 123 Serial3 321 inactive
Serial2 221 Serial1 122 inactive
Serial3 321 Serial1 123 inactive
When i Run SHOW FRAME MAP on R1 It gives output
R1#sh frame map
Serial0/0 (down): ip 172.12.123.2 dlci 122(0x7A,0x1CA0), static,
broadcast,
CISCO, status deleted
Serial0/0 (down): ip 172.12.123.3 dlci 123(0x7B,0x1CB0), static,
broadcast,
THE OUTPUT OF SH FRAME MAP ON R2 IS
R2#sh frame map
Serial0/0.123 (down): ip 172.12.123.1 dlci 221(0xDD,0x34D0), static,
broadcast,
CISCO, status defined, inactive
Serial0/0.123 (down): ip 172.12.123.3 dlci 221(0xDD,0x34D0), static,
How can i bring this pvc to be active
please help
Hall of Fame Super Bronze
Re: Frame relay problem
Can you post the output from typing show frame pvc from all the routers (R1, R2 and R3)?
__
Edison.
Appreciate your help
i was just a faulty cable which wouldnt make the pvc active
I replaced it and everything is fine
90
