frame-relay PVC x 2 same IP address why
If we have 2 frame-relay PVC configurd with the same IP address and both are up which one will traffic get routed over by default say I pinged from one end to the other? why would one do this same IP on different DLCI as apposed to assigning different ones. The reason I ask is I have come across this scenario at clients site and Im trying to work out why this was configured this way
interface Serial0/3/0
no ip address
encapsulation frame-relay
no keepalive
no fair-queue
interface Serial0/3/0.1 point-to-point
ip address 192.1.1.1 255.255.255.0
frame-relay interface-dlci 101
interface Serial0/3/0.2 point-to-point
frame-relay interface-dlci 102
Re: frame-relay PVC x 2 same IP address why
That's something I'd like to hear to.
I think it will probably load balance between the 2 interfaces.
But I've tested it.
And the router put both interfaces on the routing table:
r1# sh ip route | b Gatew
Gateway of last resort is not set
C 192.1.1.0/24 is directly connected, Serial1/0.1
is directly connected, Serial1/0.2
But it seems to send packets only using 1 interface:
Pinging from the other router:
r2#p 192.1.1.1
Sending 5, 100-byte ICMP Echos to 192.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 44/91/156 ms
r2#
*Mar 1 00:08:13.963: IP: tableid=0, s=192.1.1.2 (local), d=192.1.1.1 (Serial1/0.2), routed via FIB
*Mar 1 00:08:13.967: IP: s=192.1.1.2 (local), d=192.1.1.1 (Serial1/0.2), len 100, sending
*Mar 1 00:08:13.967: ICMP type=8, code=0
*Mar 1 00:08:14.115: IP: s=192.1.1.1 (Serial1/0.1), d=192.1.1.2, len 100, rcvd 2
*Mar 1 00:08:14.115: ICMP type=0, code=0
*Mar 1 00:08:14.119: ICMP: echo reply rcvd, src 192.1.1.1, dst 192.1.1.2
Vlad
This is certainly allowed by IOS on serial interfaces but could definitely cause issues, especially if a routing protocol such as ospf is used.
If the goal was to save IP address space then I would recommend looking at "ip unnumbered" interfaces.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
112
