Frame-relay PVC
Hi just had a quick question for you to disable a PVC all I have to do is disable the sub interface that is was created on? So if I have a pvc s0/1/0.22 and the PVC is 22 and I wanted to disable the PVC 22 all I would have to do is:
config t
inter s0/1/0.22
shut
Thanks in advance
1 ACCEPTED SOLUTION
Re: Frame-relay PVC
Just do a shut on the normal interface
inter s0/1/0
shut
That will disable the PVC of all interfaces regarding that interface/subinterfaces.
If you only want to disable the PVC of dome subinterface just shut the subinterface.
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
1 REPLY
Re: Frame-relay PVC
inter s0/1/0
shut
#Iwan Hoogendoorn
112
