Webcast-Catalyst9k
Frame Relay shaping, PVC, QoS and GRE Tunnel
I'm trying to configure QoS (CBWFQ) on a 2620XM router that run its GRE Tunnel interface through a FR PVC that has FR traffic shaping (TS)configured on the PVC as per below:
class-map match-all FTP-Traffic
match protocol ftp
class-map match-any Interactive
match protocol citrix
match protocol telnet
class-map match-any Transactional
match protocol sqlnet
match protocol sqlserver
class-map match-all Batch
match protocol exchange
policy-map QoS
class Interactive
set precedence 3
priority percent 30
class Transactional
bandwidth percent 20
class FTP-Traffic
bandwidth percent 10
class Batch
class class-default
fair-queue
interface Tunnel0
ip route-cache flow
qos pre-classify
tunnel source 192.168.155.xx
tunnel destination 192.168.155.yy
interface Serial0/0
encapsulation frame-relay IETF
frame-relay traffic-shaping
frame-relay lmi-type ansi
hold-queue 1500 out
interface Serial0/0.16 point-to-point
frame-relay class Shaping-QOS
frame-relay interface-dlci 16
map-class frame-relay Shaping-QOS
frame-relay traffic-rate 1024000 1920000
frame-relay adaptive-shaping becn
service-policy output QoS
My problem is I don't think that the config is working since it does not show any match packets as shown:
c2620XM#sho policy-map int t0
c2620XM#sho policy-map int s0/0
c2620XM#sho policy-map int s0/0.16
Serial0/0.16: DLCI 16 -
Service-policy output: QoS
Class-map: Interactive (match-any)
0 packets, 0 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: protocol citrix
0 packets, 0 bytes
30 second rate 0 bps
Match: protocol telnet
0 packets, 0 bytes
QoS Set
precedence 3
Packets marked 0
Queueing
Strict Priority
Output Queue: Conversation 40
Bandwidth 30 (%)
Bandwidth 153 (kbps) Burst 3825 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: Transactional (match-any)
0 packets, 0 bytes
Match: protocol sqlnet
0 packets, 0 bytes
Match: protocol sqlserver
0 packets, 0 bytes
Queueing
Output Queue: Conversation 41
Bandwidth 20 (%)
Bandwidth 102 (kbps) Max Threshold 64 (packets)
(depth/total drops/no-buffer drops) 0/0/0
Class-map: FTP-Traffic (match-all)
0 packets, 0 bytes
Match: protocol ftp
Queueing
Output Queue: Conversation 42
Bandwidth 10 (%)
Bandwidth 51 (kbps) Max Threshold 64 (packets)
Class-map: Batch (match-all)
0 packets, 0 bytes
Match: protocol exchange
Queueing
Output Queue: Conversation 43
Bandwidth 10 (%)
Class-map: class-default (match-any)
7427853 packets, 1871077126 bytes
30 second offered rate 147000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 32
(total queued/total drops/no-buffer drops) 0/426/0
c2620XM#
Can someone point out to me where my problem is. Thanks.
Re: Frame Relay shaping, PVC, QoS and GRE Tunnel
Hi vincent. Can you so a "show frame-relay pvc 16". The service policy is applied to a frame-relay PVC so I think this should show the required output.
Thanks Mark for your reply. Since the output exceeded the # characters limit, can you please look into the attached text file and let me know what you think. Thanks.
did you overload the PVC with traffic? If not, the counters will not encrease. The reason is, that the counters will not "see" packets CEF or fast switched. Only those packets queued will be seen, as only those will have to be treated by the CPU of the router.
You are doing CBWFQ and this is only invoked, when there is an overload situation. So use a traffic generator and make sure you get some drops as a sure indication of overloading the interface. If the counters still are not increasing, then the policy does not work and further investigations are needed.
Regards, Martin
hi, I see everything is going into the default queue. Just to make sure that traffic is coming in as expected can you enable "ip nbar protocol-discovery" on the inbound interface then do "show ip nbar protocol-discovery" to check that traffic is entering the router as you expect. If this is the case then I wonder if "qos pre-classify" is working correctly in your scenario. I've never used this feature before but as far as I can see you have configured it correctly. Can you respond with the previous nbar commands?
Gents.
Thanks again for your posts. My answers to the two previous posts are as followed:
1. "Overloading the PVC" - I think that I'm definitely overloading the PVC. I have similar configuration at a different site and it's working fine. The only difference is the other site do not run via the GRE Tunnel interface but instead the FR PVC.
2. I've configured "ip nbat protocol-discovery" as requested. Attached is the output of the requested show command. Also, I've made sure that the destination (10.95.3.0/24) is via the Tunnel0 interface from this router.
Hi Vincent. I setup your script in a lab and had the same issue. I believe the problem is because you are trying to classify and queue on the outbound interface. You need to split this up over different interfaces. Classify and mark traffic on your ingress interface. Then take action (queue) on the egress interface. I have configured this and it worked fine!
Thanks Mark for the reply. Is there any chance that you can show me the config that you setup in the lab that works?
sure (see below). I've not completed the queuing for all classes but I'm sure you get the idea.
class-map match-all ICMP
match protocol icmp
match protocol ftp
class-map match-all Batch-out
match ip precedence 1
class-map match-all ICMP-out
match ip precedence 0
class-map match-all FTP-out
match ip precedence 2
class-map match-all interactive-out
match ip precedence 4
match ip precedence 5
policy-map QOS-OUT
class FTP-out
class ICMP-out
bandwidth percent 5
class interactive-out
priority percent 30
class class-default
fair-queue
policy-map QoS
class Interactive
set precedence 4
class Transactional
set precedence 5
class FTP-Traffic
set precedence 2
class Batch
set precedence 1
class ICMP
interface Tunnel0
ip address 31.31.31.3 255.255.255.0
qos pre-classify
tunnel source 1.1.1.3
tunnel destination 1.1.1.1
interface FastEthernet0/0
ip address 20.20.20.3 255.255.255.0
ip pim sparse-dense-mode
duplex auto
speed auto
service-policy input QoS
interface Serial0/0
no ip address
no fair-queue
hold-queue 1500 out
interface Serial0/0.31 point-to-point
ip address 1.1.1.3 255.255.255.0
frame-relay interface-dlci 301
class Shaping-QOS
ip route 0.0.0.0 0.0.0.0 Tunnel0
service-policy output QOS-OUT
258
