02-26-2007 06:22 AM - edited 03-03-2019 03:56 PM
I have 2 t1 CSU/DSU WIC card in cisco2800 and cisco2651 XM. This is my fisrt time doing this. Can you please specify which cable exactly I shd use:
Frame-relay switching is enbaled on both routers globally...
below is my config
interface Serial0/0
description FR switch
no ip address
encapsulation frame-relay
no keepalive
no fair-queue
frame-relay interface-dlci 201
interface Serial0/0.21 point-to-point
ip address 131.1.12.2 255.255.255.0
interface Serial0/3/0
no ip address
no keepalive
frame-relay lmi-type cisco
frame-relay intf-type dce
interface Serial0/3/0.12 point-to-point
ip address 131.1.1.1 255.255.255.0
frame-relay interface-dlci 101
02-26-2007 06:52 AM
Configuring frame relay:
http://www.cisco.com/en/US/tech/tk713/tk237/tech_configuration_examples_list.html
02-26-2007 07:22 AM
Thanks for your help.
The interface is still down. I am using a xover cable between both router and it is till not working....
02-26-2007 07:54 AM
Which csu/dsu are you using? Did you configure the controller correctly?
I suggest you tray to get the T1 link working first and then change encapsulation to FR.
