05-19-2008 04:01 AM - edited 03-03-2019 10:00 PM
I had recently requested an upgrade from my service provider on one of my frame-relay site. Is there a way to verify if an upgrade has been done on my pvc?
Regards.
05-19-2008 04:29 AM
check the input and output packets on the interface.
05-19-2008 04:33 AM
HI [Pls RATE if HELPS]
Use the WAN KILLER Tool to TEST the Circuit.
Using the Tool you can PUMP the Traffic to until your requested Bandwidth. Observe the Input & Output rate on the WAN Interface.
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
05-19-2008 06:44 PM
Hi there,
Thanks for the info but appreciate if you can give more details. How can i confirm the speed with the following sample:
48482432 packets input, 1326954085 bytes, 0 no buffer
21114144 packets output, 2743938039 bytes, 0 underruns
Many thanks.
05-19-2008 07:53 PM
HI, [Pls Rate if HELPS]
Pleaes execute the below command and paste:
Router#sh int Gi3/3 | i rate
Queueing strategy: fifo
30 second input rate 15582000 bits/sec, 9299 packets/sec
30 second output rate 58686000 bits/sec, 12625 packets/sec
Refer the "INPUT & OUTPUT" Rate value in the output above and they calculated in bits/sec.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
