Community Member
Frame Rerrors troubleshooting
Need some help toubleshooting.
Following Error:
0 input errors, 0 CRC, 654843447 frame, 0 overrun, 0 ignored
It seems like I am receiving a checksum error?
Is there a cisco posting on diagnosing the issue.
Now this router is connected via gigaethernet to a C4500 router.
No errors on the C4500 series router.. all values of 0.
Please and thank you.
Hall of Fame Super Gold
Re: Frame Rerrors troubleshooting
Please post the complete show interface, and show controller.
Community Member
Show interface
is up, line protocol is up (connected)
Internet address is x.x.x.x/x
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 44/255, rxload 38/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is LH
input flow-control is off, output flow-control is on
Clock mode is auto
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:56:04
Input queue: 0/1000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/1000 (size/max)
30 second input rate 152121000 bits/sec, 34347 packets/sec
30 second output rate 172617000 bits/sec, 31325 packets/sec
L2 Switched: ucast: 258 pkt, 20675 bytes - mcast: 443 pkt, 590082 bytes
L3 in Switched: ucast: 111581966 pkt, 62557003965 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 100470594 pkt, 70532676752 bytes mcast: 0 pkt, 0 bytes
111754322 packets input, 62646462900 bytes, 0 no buffer
Received 443 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 1061762626 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
100636255 packets output, 70647745725 bytes, 0 underruns
Community Member
Not really anything that indicates an issue, but I could be missing something.
One tool I use to diag interface issues is Cisco's Output Interpreter
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl?locale=en
Community Member
show interface controller
reliability 255/255, txload 45/255, rxload 38/255
Clock mode is auto
Last input 00:00:02, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:52:39
30 second input rate 149433000 bits/sec, 34574 packets/sec
30 second output rate 180297000 bits/sec, 32019 packets/sec
L2 Switched: ucast: 243 pkt, 19467 bytes - mcast: 416 pkt, 556107 bytes
L3 in Switched: ucast: 104786211 pkt, 58826126453 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 94207598 pkt, 66155135941 bytes mcast: 0 pkt, 0 bytes
104689547 packets input, 58767134784 bytes, 0 no buffer
Received 415 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 997086730 frame, 0 overrun, 0 ignored
94131086 packets output, 66105321147 bytes, 0 underruns
0 output buffer failures, 0 output buffers swapped out, loopback not set
Clock mode is auto
Hi, considering that it is a L3 switch, you should ask the question in the "lan switching" forum.
It seems a false error indication to me, but I can be wrong.
Community Member
in this case you are receiving the errors (frames), so i guess the problem is in your physical port that is receiving frames whithout adding CRC errors which surely would indicate transmition problems.
Make a loop test in your interface, a kind of local-loop which will show you if the same transmitted path is received.
hope it helps
rgds
Community Member
check ur duplex setting and speed setting both in the switch and next machine
Remove auto mode and use specify mode like 10MPS and Half duplex and see if u sill getting the error as these things happens because of these error( cisco also recommend to code manually)
212
