Webcast-Catalyst9k
FRF.12 on IOS 12.0(30)S
Anybody has done FRF.12 (Frame-relay fragment) on a map class on a 7200VXR with 12.0(30)S IOS ? I see that is not supported, and I do not know how to do it in any other way! Help is appreciated.
Luis
Purple
Re: FRF.12 on IOS 12.0(30)S
Luis,
I'm pretty sure that is supported. What bit does not work for you ?
Paresh
Paresh,
The first thing is that Shaping is supported through DTS like commands (nested policy map and doing shaping on parent), but the when I try to use the frame-relay fragment on the map-class frame-relay, there is no such command, take a look....
7206VXR#sh ver | inc 12.0
IOS (tm) 7200 Software (C7200-K4P-M), Version 12.0(30)S5, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(30)S5, RELEASE SOFTWARE (fc1)
7206VXR(config)#map-class frame-relay FRF-TEST
7206VXR(config-map-class)#frame-relay ?
adaptive-shaping Adaptive traffic rate adjustment, Default = none
bc Committed burst size (Bc), Default = CIR
be Excess burst size (Be), Default = 0 bits
cir Committed Information Rate (CIR), Default = 56000 bps
custom-queue-list VC custom queueing
fecn-adapt Enable Traffic Shaping reflection of FECN as BECN
mincir Minimum acceptable CIR, Default = 1/2 CIR
priority-group VC priority queueing
tc Policing Measurement Interval (Tc)
traffic-rate VC traffic rate
7206VXR(config-map-class)#frame-relay fragment 640
% Invalid input detected at '^' marker.
Luis
Purple
Luis,
I just did a check on feature navigator and it seems that you need at least 12.0T for it. The 12.0S train does not support it but the 12.2S train does...
Pls do remember to rate posts.
Paresh
Paresh,
The thing is 12.0S is needed for the MPLS, AToM support.... 12.2S does not offer all the features 12.0S does, but i'm sure there must be other way.
Luis
96
