frf.16 and voip
hi,
we have a lot of frf.16 connections for dataconnections.
since about half a year we transport voip over these frf.16 bundles.
we are using llq (a service-policy)on the main-interface.
BUT:
what about the load-balancing mechanism which makes the paket decision?
if for example one voip paket is transmitted over the first of two bundle lines and if the comes a large data paket in, which is forwardet over the second link could it be that further voip pakets comes to the far end in a different order - so that the seq# of the rtp pakets are in a wrong order?
if yes - what is the solution ?
thanks for any answer !
1 REPLY
Re: frf.16 and voip
The answer is that if you are using a link <768k you should be fragmenting the packets so that your traffic is not excessively delayed. There is a jitter buffer on either end of the link that should handle any delay variation.
109
