from verizon T1x2 on 1841 to 10meg on 2801
We have a T1x2 on an 1841 router, we are moving to a 10meg and i thought i can use a 2801 router we had sitting around (Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(7), RELEASE SOFTWARE (fc6))
1.
the Verizon engineer gave me a code sample to help with the move, but when i try to apply "ip virtual-assembly" command the router "invalid input"s me.
I guess this command is not available on the 2801 ver i have?
also
2.
since the 10meg line doesnt need a wic for serial connection etc, only a FastEthernet port, and i only have 2 of those, i tried to modify the code to include my inside network ip, so devices can connect to it (i use this IP as the gateway for all ip settings).
im not sure if this is the right way of doing this.
interface FastEthernet0/0
description LAN
ip address {verizon ip address} 255.255.255.252
ip address 172.16.1.2 255.255.248.0 secondary---->i added this hoping it will work with my internal switch
speed 100
full-duplex
no shut
interface FastEthernet0/1
description IDE US TIERED 10M VERIZON
no ip address
ip virtual-reassembly---->this line doesnt take
no shutdown
duplex full
speed 100
interface FastEthernet0/1.36
ip address {verizon ip address #2} 255.255.255.252---->this line doesnt take either
encapsulation dot1q 36
ip nat outside
no shutdown
duplex full
speed 100
  • WAN Routing and Switching
1 REPLY
Hall of Fame Super Gold
You can ignore virtual-reassembly, but must be able to enter Ip address.
I recommend that you engage a professional for the task.
252
