FRTS make it me clear?
FRTS, Unlike the other shaping tools, cannot shape a subset of the traffic on an interface. Each of the other three shapers can be configured on one suinterface and not the other, essentially enabling shaping on only some of the traffice leving an interface. The other three shaper can also configure classification parameters and shpe only part of ther traffic on the interface.
PLEASE HELP ME TO UNDERSTAND THIS???
(What it means)
regards
devang
Purple
Re: FRTS make it me clear?
Hi Devang,
When you enable FRTS, it is done using the command 'frame-relay traffic-shaping'. This command is applied at the physical (main) interface level, not at a sub-interface level. As soon as this command is entered, all frame-relay PVCs under this interface (including PVCs under any sub-interfaces) will get default traffic-shaping parameters (you can override the defaults using frame-relay map-classes). That means that as soon as this command is entered, all PVCs on that interface will be shaped. You don't have the option of shaping some PVCs and not others.
For example:
interface Serial0/0:1
no ip address
encapsulation frame-relay IETF
load-interval 30
no fair-queue
interface Serial0/0:1.16 point-to-point
ip address 16.1.1.1 255.255.255.0
frame-relay interface-dlci 16
interface Serial0/0:1.17 point-to-point
ip address 17.1.1.1 255.255.255.0
frame-relay interface-dlci 17
In the above config, both DLCIs 16 and 17 will be shaped. You cannot just shape one and not the other. Also note that you can't enter the 'frame-relay traffic-shaping' command under a sub-interface.
The other shaping tools, such as class-based traffic-shaping and generic traffic shaping (GTS), can be a bit more granular. With GTS you can use ACLs to determine what traffic gets shaped. With CBTS, you can do it on a per-class basis.
Hope that helps - pls rate the post if it does.
Paresh
thank you pareshbhai,
so it means that when i enable FRTS on main interface all PVC will be enable to shaping right??
now tell me if i am having 4 PVC and i would like to use different shaping parameters on PVC then is it possible in FRTS ???
and also send me good links to read FRTS in depth...???
regards
Devang
Purple
Hi Devang,
In order to shape PVCs at different rates, you need to specify the shaping parameters in a frame-relay map-class.
An example follows:
no ip address
load-interval 30
no fair-queue
class shape128k
class shape256k
map-class frame-relay Shape128k
frame-relay cir 128000
frame-relay bc 32000
map-class frame-relay Shape256k
frame-relay cir 256000
frame-relay bc 64000
DLCI 16 will be shaped to 128k and DLCI 17 will be shaped to 256k
Here's a couple of good links:
http://www.cisco.com/warp/public/125/21.shtml
http://www.cisco.com/warp/public/125/traffic_shaping_6151.html
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/qos_c/qcpart4/qcfrts.htm
Paresh
114
